i'm baaaack....
hey guys,
iv got a mate who wants to convert his 1991 TX-3 to a turbo model, what parts does he need and how much will it cost? cheers |
Over Thinker
most buy a donor car and refit and rewire the registerd one
cost is just of the 1/2 cut or whatever costs less if you can do it yourself most just bolts on even better to hear the donor engine running turbos can be damaged internally and not show any sign
My car goes Brumm Brumm |
#3 | |||
What a performer!
1981 Ford Laser KA :: E5 :: 2002-2003 1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW 1990 Ford Laser KF TX3 :: BP :: 2010-2011 1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW 2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW 1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020 2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-* 1998 Ford Falcon AU XR6 :: HP Intech :: 2021-* |
i'm baaaack....
CRIKEYS!
i didn't think it would have been that much! we thought it was just turbo, manifold, piping, get the ECU re-tuned. his car is also a FWD so will the standard G/B handle the punishment of a turbo? btw, he is a mechanic, so he can do it all himself. |
#5 | ||||
What a performer!
Gearbox handling the power - Short answer yes, long answer no. It'll handle power of up to ROUGHLY 110fwkw if you treat it nicely. Though hard gear changes will make your box into little crumbly bits on the ground. Quote:
You CAN do the BP to BPT conversion on the cheap. Under 3k is doable. Just not advisable. There's nothing worse than spending a lot of money to just have everything die months later if you spent the money doing it right. Know what I mean? If you played it slow, found good cheap items (which do pop up) and did it 'on the cheap' .. Engine: $1400~ Box: Use current G series ECU+Wiring: Free if you mate your current loom with the turbo loom Mounting: $300~ Consumables: $200 Example.. I remember when everyone said ROB GET A NEW WATER PUMP THE BP ONES DIE AND YOU MIGHT AS WELL DO IT WHILE YOU'RE DOING THE CONVERSION and I didn't listen. What happened? TWO MONTHS after I finished my conversion the water pump died on me. Pain in the bloody ****, had to take the engine out to change it. Anyway sorry for the essay buddy, anymore questions feel free.
i'm baaaack....
also, if the turbo turns out to be to expensive for him,
how can you hot up the Standard TX-3 motor? ie; cams, pistons, exhaust, air intake ect ect |
i'm baaaack....
cheers mate, your help is great!
ill see what he thinks of it. and yeh he wants more like 120 front wheel killowatts, and he really will give it a hard time i think (hard shifts, burnouts, dropping clutch ect ect) we have found a retreived stolen vehicle thats had the interior and body parts taken off, its an AWD though. (TX-3 Turbo) its the same model as his i think. will all the turbo stuff just bolt in? or will it be a pain to get it all set-up ect ect? |
What a performer!
You can use everything from the 4WD TX3 (when I say that I mean swap the engines, NOT change over the manifolds etc) except the gearbox.
Tell your mate that even the strong turbo gearbox is weak as ****. They are the bad points of the car, and when they cost $800 each, you don't want to act like a clown with them. Dropping clutches, you'll destroy a box in weeks.
i'm baaaack....
hrmmmm
i think i will tell him that... he wont be happy when he has to drop his own box out lol is there a stronger box avaliable for these? |
What a performer!
Yes but only in 4WD form. ( Mazda Familia BG GTR ) and you're looking around 2k each for those IF you can find one.
i'm baaaack....
sounds very expensive....
i think i will tell hime to watch his driving cheers heaps for that VippiN |
#12 | ||
03 LR Focus / 90 KF TX3 T
Even then the GTR boxes are basically the same but for a shot and peened first and second, plus IIRC a wider 5th gear.
Estimate about $4.5k for the whole job. As for usable parts off the stolen / recovered, you also can't use the carpet, hubs, suspension, gear selector assembly, drivers seat, power steering, drive shafts I think and some other stuff I'm not too sure about (brake booster etc). Also be aware that the stock ECU in the 4WD is lower kw (117kw) than a front cut Jap ECU (134kw) due to our shitty fuel. You might be better off buying a motor from someone with a cheap setup for sale (like mine for $1100!, unfortunately in Adelaide ![]() Just something to take into account if you're intending to use parts from the car as well rather than just the motor. Drive any laser, even an N/A like an idiot and you'll wreck the gearbox (as I found out the hard way), so the more power you put through it, the more likely you are to do the damage. Things to do while doing the conversion is the spigot bearing on the gearbox, waterpump (as vippin said), timing belt (they're like $20 or something), CV seals, oil seals and any vaccum hose with splits (check them all!) |
i'm baaaack....
ok cheers mate!
im not 100% this conversion will happen now, somebody has just given him a stupidly good offer on the car, so it might already be sold. still the info is handy in case this bloke doesnt come through with the cash. |
#14 | ||
AFF Post NAZI
couldnt your mate just buy a 4wd Tx3 turbo for about 5-7k and save the hassle?
just a thought.
"Its not always about power, The car has to handle Beautifully" |
#15 | |||
i'm baaaack....
but at the time he was strapped for cash, so he got a TX-3 for $2500 with 11months reg and RWC very good deal, but he's probably selling it now, just need to work out if this other guy is going to come through with the goods. |
