hi,i have a 2.0ltr twin cam efi 97 telstar contour.How do i get the 2 camshaft and crank cog aligned.The belt was off and cogs moved.How can i move the cogs without damaging something.information much appreciated
Over Thinker
I dont know the engine myself
this I remember with the crank at TDC the rockers need to be sitting at the back of the cam of The number one cyl ie rocking or maximim clearence one is supposed to mark both cams and the old belt before removal for this very problem you have Is there no line marked on both cam sprockets ..if there is.. both should be straight up at the top while the pully crank is at TDC If you belong to a breakdown service they may have advice for free or suggestions a mechanic , ford service division , try to find a ford repair manual
My car goes Brumm Brumm |
there is an 'I' and 'E' stamped on the front of each cam pulley.Due to unfortunate circumstance cogs out of time.No marks done.Thanks anyway.
Over Thinker
trying to find an answer for you .will keep looking
![]() http://www.aa1car.com/library/2004/eb90428.htm http://www.aa1car.com/library/2004/us70444.htm
dirty hands please help i put my key in the ignition and it wont turn and jams in ignition of my tx5 telstar just started to do this today what should i do
Last edited by kerrilisa; 03-12-2006 at 11:00 PM. Reason: imnot sure what im doing to get a reply |
Over Thinker
kerrilisa - pm sent if the lock graphite doesnt work off to a locksmith
