Old 22-10-2006, 10:39 PM   #1
Envi XR8
I love my beast too!
Envi XR8's Avatar
Default which shifter is the best one to use
Hi all,
I was wondering what everyone's thoughts are on which shifter is the best to use???.
I currently have a StarShifter that I was going to use, but found that both the Quiksilver and Promatic2 might be better. I want to be able to use the car when it is built mainly for the drags, but also a bit of everything else too.
From what I can gather, and I could be very wrong (and if so please let me know) these shifters allow you to move up and down gears, and would be better to use for the street driven/racer toy that I am yet to find.
any thoughts?
cheers and thanks in advance,
Envi
Envi XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2006, 11:15 PM   #2
Coupe460
Coupe460's Avatar
The nicest auto shifter from 2 , 3 , 4 speeds in my opinion would have to be the B&M Pro Ratchet, cheers jai
Coupe460 is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2006, 11:25 PM   #3
ToddZC
Thunderbolt driver
ToddZC's Avatar
I second that. I'm using the B&M Pro-ratchet, and even with a manual valve body, it is easy to use on the street and strip.
ToddZC is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2006, 11:29 PM   #4
ratter
ratter's Avatar
I've tried b&m starshifter and megashifters in my ZC and in the end went to and still use a Hurst promatic2 shifter, it appears to be easiest to use with the manual valve body, it has gear indicator display, and uses neutral start switch and reverse light switch to keep it close to legal.
Pit Lane Performance
Old 22-10-2006, 11:55 PM   #5
brenx
brenx's Avatar
I used to have a Megashifter. Never liked it due to how much of an effort it was to get into reverse. I swapped to a Quicksilver. I'll never use a Megashifter again. I converted the Quicksilver from a 3/4spd shifter for use with my 2spd powerglide.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2006, 07:47 PM   #6
Envi XR8
Envi XR8's Avatar
yeah the hurst promatic is probably my personal pick, although the Quiksilver does the same thing so I guess it comes down to what is available and for how much....
Old 23-10-2006, 08:46 PM   #7
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
Pro 5.0 for me.....not sure how'd you'd adapt it..... ;)
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2006, 09:34 PM   #8
jd dad
Pro Ratchet for me, good allrounder and has reverse/nuetral switch as well
successfull trades with davway,ozziechief,Damon, Big Trev, Howey, BJ , Niko, Davocol,klawsterfobik and XCwillo
jd dad is offline   Reply With Quote Multi-Quote with this Post
