Old 22-09-2024, 03:33 PM   #1
whitelion65
whitelion65's Avatar
Default Damaged fastener removal service
Hi folks,
Is anyone aware of a stripped screw/bolt removal service in Orange, NSW.
I HAVE A 2mm Allan grub screw in a sewing machine that has been munted.
I’ve tried jamming a torx driver in, and an easy out. The screw is only 4mm long, so getting purchase is difficult.
The other screw on the shaft was severely overtightened, but I was able to get it out in one piece using Allan key and scanner.
I have used penetrating oil and freeze spray on the damaged one , without luck.
Steve
Steve
Current rides
2012 Mondeo Titanium wagon (TDCI)
Moondust silver
2016 Focus Trend, 1.5ecoboost, 6sp manual.
Frozen white
Previous
2004 Berlina Wagon (LS1) Vespers Blue
1995 Camry 2.2, white
1971 Ford Fairmont wagon 302w, C4 Polar white
1971 TC Cortina, 2L 4sp, Ermine white
whitelion65 is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2024, 04:23 PM   #2
Default Re: Damaged fastener removal service
No; but what about:
Hidden Talent Orange
Sewing Machine Repairs & Service
Shop 1 153/157 Peisley St, Orange NSW 2800
(02) 6362 0011
Or drill it out with a reverse (left hand) drill bit (e.g. https://www.amazon.com.au/YUENTOEN-E...s%2C301&sr=8-6) and replace it perhaps.
Old 22-09-2024, 04:29 PM   #3
"Scanner"; how was that used?
Old 22-09-2024, 05:23 PM   #4
whitelion65
Spanner!
Bloody autocorrect
Steve
Current rides
Moondust silver
Frozen white
Previous
Old 22-09-2024, 05:26 PM   #5
whitelion65
Thanks,
We are an authorised service agent.
This is a case of a knucklehead butchering something.
No; but what about:
(02) 6362 0011
Steve
Current rides
Moondust silver
Frozen white
Previous
Old 22-09-2024, 05:28 PM   #6
whitelion65
Has anyone had experience with Kingchrome quick-outs?
Maybe on a pedestal drill, they could do the job?
Steve
Current rides
Moondust silver
Frozen white
Previous
Old 22-09-2024, 05:36 PM   #7
hawke
hawke's Avatar
I work on a lot of old shitty cars, and use these things:
https://www.bunnings.com.au/irwin-3-...76224_p0621022
Never failed yet.
Not sure they go down to 2mm.
hawke is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2024, 05:37 PM   #8
Kincrome perhaps.
Aldi have similar items on special buys at the moment too. Same as these: https://www.aldi.co.uk/workzone-dama...96188205481300
Old 22-09-2024, 05:41 PM   #9
This type usually works well on grub screws:
https://www.totaltools.com.au/123619...ce-ttisfses5pc
Old 22-09-2024, 05:45 PM   #10
2mm - if that’s the major diameter - is so small, I’d think you need to make a drilling jig. Hole is blind?
Citroënbender is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2024, 05:57 PM   #11
383hq
Depending on how munted, munted actually is,
a 3/32" imperial hex key is a little larger then metric 2mm
forced in, it might be enough...
383hq is offline   Reply With Quote Multi-Quote with this Post
Old 22-09-2024, 06:12 PM   #12
whitelion65
I have the shaft out, so have access to the screw. I’ll post a pic…if my acquired brain injury will allow!
I get the feeling that experience counts in a situation like this…hence my cry for help.
Steve
Current rides
Moondust silver
Frozen white
Previous
Old 23-09-2024, 08:24 PM   #13
XD 351 Ute
Excessive Fuel Ingestion
XD 351 Ute's Avatar
Is the shaft able to be set up in a lathe, a good machinist should be able to do something with it, perhaps using the left handed drills mentioned previously.
A gentle bit of heating may help if possible.
Ed
Recommended Forum Traders: RSGerry, trimmaster, 51OAU, EB-92, adxr8, my67xr, RG, ZA-289, kruptor, gassa, Felony, RNXR, Rhino 351, Anchor, Smoke Pursuit, Mr. FPV (through E-Bay),
XD 351 Ute is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2024, 02:33 AM   #14
4ttl
Heating it gently can also help loosen things up.
4ttl is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2024, 09:10 PM   #15
Tonz
whats the end result
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent
Tonz is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2024, 06:19 AM   #16
whitelion65
Bad result!
After heat and freeze spray, the easy out I used chewed the grub screw out, tith the bottom of it holding fast.
The fitting has been ground off and replaced.
I’m sure a machinist could have drilled it out, re-tapped and installed a larger grub screw. But at what cost? And the danger of damaging the shaft.
Steve
Current rides
Moondust silver
Frozen white
Previous
