Old 13-05-2023, 04:46 PM   #1
XL62
Default Ford Focus 2018 Error code P2111
My wifes 2018 1.5L Ford Focus 60,000kms has the engine light ON and goes into limp mode. Scan tool indicates error P2111 - Throttle stuck open. There does not seem to be any other errors just the P2111. I can clear the code and engine idle is restored (is very lumpy when engine light is on) and you can drive it very slowly but as soon as you try to accelerate it goes into limp mode, engine idle lumpy and engine light ON. Presently in Hidden Valley Ford here in Darwin, throttle body flap does not seem to be stuck but the Ford dealer does seem to be. Any information on a possible cause and way forward appreciated. Cheers Tony
XL62 is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2023, 04:57 PM   #2
Fordman
Fordman's Avatar
Default Re: Ford Focus 2018 Error code P2111
See here for leads that seem to be ford related: https://www.troublecodes.net/p2codes/p2111/
I've also heard from people to check the car battery and that sometimes low battery does funny things.
Fordman is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2023, 05:42 PM   #3
XL62
Thanks Fordman, the problem will be getting someone in the service department who can do more than change oil. I will show them the notes I have made from the info you put me onto and get them to test the battery first. Thanks again Cheers Tony
