for a non car related project I need (if such a thing is possible) 3-5 wafer almost paper thin washers, I have a metal plate that needs to align with a table saw blade.1/8" dia would be ideal. where from?
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent |
Formerly ST170ish
My bad attitude escalates in direct proportion to the amount of stupidity I am presented with!!! ![]() |
shim washers thankyou
I remembered the name around 2.30 this morning but stuffed if I was doing anything about it then.
After seeing the prices of these shims, may I suggest experimenting with aluminium foil.
I've worked wonders with this stuff and you may be surprised with the results. |
cheers, been suggested elsewhere xray film and icecream container plastic, like that good excuse to eat more ice cream
If I needed a shim when working, shops usually closed I would just cut up an old coffee tin!......
Any good motorcycle suspension place will have a range of shims.
I know that Tecnik at Penrith has a wide range and an online shop. |
What about a set of cheap feeler gauges?
fair go guys, I appreciate your (left Field) suggestions, but the old ice cream (home made peanut butter & chocolate) took a hammering at lunch time now I sit here bloated.
but the container was put to good use as was some tin foil. problem solvered.
