Old 15-01-2015, 04:42 PM   #1
V1nn1e72
Exclamation there is a problem
i have a mk2 escort ghia (My first car) and the reverse light is stuck on and i dont know why. (1976, 1.6L) anyone have any ideas.
Everyone has bad days. The cure is to drop it down a gear, put the foot to the floor and flick out the tail end.
V1nn1e72 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2015, 04:48 PM   #2
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Default Re: there is a problem
Sounds like the reverse light switch is sticking on.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2015, 11:49 PM   #3
dirty hands
Over Thinker
dirty hands's Avatar
till you get it sorted take out the reverse light bulbs
My car goes Brumm Brumm
Old 17-01-2015, 09:45 PM   #4
freeo75
There is a reverse light switch screwed into the gearbox near where the gearstick is located, but underneath the car. The wiring connector plug to it may have come loose and is earthing or your switch is knackered. If all seems ok there follow the wire (orange from memory) inside the car where it goes behind the heater box and up to the loom under the dash. If all ok you have wiring issues probably at your rear lights
freeo75 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2015, 01:57 AM   #5
JT.
also check your engine mounts. mine had a broken one which caused the driveline to twist enough to earth the switch against the body.
JT. is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2015, 11:08 AM   #6
V1nn1e72
after working on it for many hours with a professional we found that the whole switch assembly had shattered in half. I have never seen anything like it, but the problem should now be sorted
