Old 07-11-2011, 03:57 PM   #1
ASLTech
Default Car Pc Interface For Ba/bf/territory & Fg Now Avaliable
ASL has released it's long awaited CAR PC Interface for BA/BF/Territory and FG Series 1 Vehicles. PRICE $245
FEATURES:
• Pure hardware design, just Plug and Play Display, No Software Driver requirement, compatible with any operation system.
• Support PC 640x480@60/72/75/85Hz, 800x600@56/60/72/75Hz, 1024x768@60Hz display mode.
• Support MAC 640x480@66Hz display mode.
• True 24 bit A/D converter for the true 16.7 million color conversion.
Designed Specifically to intgrate with BA/BF/Territory and FG vehicles.
Plug and Play Solution - No cutting of any wires.
This will connect to any PC/Laptop that has the correct Resolution (See above).
Auto Screen Triggering - Detects PC has been switch on and triggers screen when handbrake is engaged.
PLEASE SEE WEBSITE FOR MORE DETAILS or CONTACT FADI
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
ASLTech is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2011, 04:17 PM   #2
GhiaEB
2004 TX Territory
GhiaEB's Avatar
Default Re: Car Pc Interface For Ba/bf/territory & Fg Now Avaliable
Do you need the handbrake engaged? If your running Nav software that might be a problem.
Sadly the EB is dead....
Now a AWD TX Territory Daily
P6 Silver Monarch Weekender
And on 2 Wheels,
ZZR 250
Can do mixer shaft replacement on BA-BF Falcon and SX-SY, fix your heater Today. PM For more details
For sale: Heaps of Territory bits and bobs including front brembo doglegs, NOS I-design territory body kit painted offshore, also FPV 290 engine bits. FS thread here http://www.fordforums.com.au/showthread.php?t=11397826 Pm for more details.
GhiaEB is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2011, 01:45 PM   #3
ASLTech
We design it to connect to the Handbrake Ground.
CHeers
Old 12-12-2011, 06:00 PM   #4
hamoudy10
Ford Nut
hamoudy10's Avatar
just connect it to any ground...
Heritage EL Fairmont Ghia - Turbo DOHC Build
Petroleum FG MKII XR6 Turbo - 350rwkw
Magnetic 2017 Mustang GT - 300rwkw
hamoudy10 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2012, 10:34 AM   #5
Sick EB
ORSM Ford Cruisers
Sick EB's Avatar
Any chance of doing a group buy to get these cheaper?
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread
2008 FG XR8 SEDAN 300RWKW N/A
2008 FG XR6 TURBO-UTE>>> SOLD
2002 AU3 XLS UTE>>>SOLD
Sick EB is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2012, 10:49 PM   #6
Sick EB
ORSM Ford Cruisers
Sick EB's Avatar
Also just wanted to know if you can still use the climate control ect with the pc on? Also can the screen 'trigger wire' have a switch put in to have the screen manually change to pc mode? Also is the vga cable you say is not included a normal red, white and yellow? And is the screen able to be connected to the pc via a blue type multi pin monitor cable.
Thanks. matt
Old 20-02-2012, 10:30 AM   #7
ASLTech
Thanks. matt
Yes you can use the climate control as normal, you can put a switch in if you like and it is a regular 15 pin video cable.
Old 06-05-2014, 02:02 PM   #8
quazzar
FEATURES:
Cant see links yet, not enough posts im told
now I can
quazzar is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2014, 04:46 PM   #9
shaine71
Shaine
shaine71's Avatar
will this work on FG Mk 1 black and white screen
2010 GS 315,S/S 3INCH X-Force,,6/4brembos,Shockworks Coilovers
FOR SALE...
shaine71 is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2014, 07:48 AM   #10
FADI75
Sponsor
hi
sorry we no longer supplying this product
cheers
fadi75
FADI75 is offline   Reply With Quote Multi-Quote with this Post
