Old 13-11-2010, 02:35 PM   #1
cougs61
Old but not slow
cougs61's Avatar
Default A couple of Q's
Does the rear "brake light" on the boot actually work or is it just a reflector?
Also, is there a place in Australia that makes or supplies body kits for Cougars?
My Website..
cougs61 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2010, 02:54 PM   #2
baz
The brake light on the boot is supposed to work, mine does.
baz is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2010, 05:26 PM   #3
cougs61
Old but not slow
cougs61's Avatar
Hmmmm, mine isn't even wired up. Not even a bulb in it.
My Website..
Old 14-11-2010, 06:13 PM   #4
REDDYZ
REDDYZ's Avatar
It should work and am guessing that the bulb holder and wire must have fell behind. You will need to open the trim inside the boot (rear of hatch door) to access it and plug it back in the light case. No reason for anyone to chop it. Am sure it must have fell behind.
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can.
Now driving a Lexus RX 450h. Your guess is correct that I am a family man now.
REDDYZ is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2010, 10:43 AM   #5
thearrow
There no local manufacturers of body kits in Australia so you will have to import one from the USA. Best thing to do is get on line and check which kind yuo want as there is quite a variety and take it from there.
thearrow is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2010, 01:55 PM   #6
cougs61
Old but not slow
cougs61's Avatar
Woohooo, after a bit of a search, found said holder. It had dropped way down into the boot section, so all is good now.
Thanks REDDYZ for pointing me in that direction...
My Website..
