RS2000 Front end, Intercooler, Custom oversize Radiator, Sierra 5 speed manual, Heavy duty Clutch, LSD Diff with disc brake rear end. Custom Headvy Duty Tail Shaft. Ventilated front disks, Koni shocks all round. HD fromt sway bar, Fully fuel injected, Wolf 3d injection, Garrett GT28 Ball Bearing Turbo. Oversize sump. The car has a modification permit and is fully WA licensed. Runs really well, heaps of Power.
Has one patch of rust in the panel behind the drivers side rear door. Rest of car is top notch, due for a respray. $9,000 I can be contacted on 0419031550 |
What does 'Fully fuel injected' mean?
it means it is running on a Wolf 3d Programmable fuel injection EMS.
#4 | |||
71 Mk2 Cortina owner
hey mate jus wondering, where'd you get the efi stuff from? im looking for some.
Need any tiling done? no job too small competitive rates anywhere in adelaide. pm me or give us a call on 0418850384 |
Dont know what state your in but I got mine from Fjordfour in mordialic for $500. A cheap alternative is to run a camira computer and take a pinto dizzy with the camira one down to a machinest and put the top half of the camira dizzy to the bottem half of the pinto one. It run quite well. But for the money of about $1000 twin webers produce more power like i found out
I got the EFI manifold from Rolly @ Racetune.
Injectors - Petroject Bosch ignition module - Petroject VL Fuel pump - Coventries Rising Rate Fuel Pressure Regulator - Petroject Fuel Rail -Custom made, from Aluminium Tube stock Crank angle Sensor - Ford Falcon part. 4 CDI Coils - VL Commodore Part - Coventries Wolf 3d System - came from a company called SST, which is no more. Try Wolf3d on the net, there is a web site. If I was to do over I would use a E4 haltech system. More map points makes the car run smoother. |
