Hi guys, can anyone point me in a direction as to how I program a new remote for another AU I just bought that didn't come with one?
The Origional, The Best
turn your key to accessories
press the rear demister button 3 times within 5 secs the door locks will cycle (lock then unlock) to confirm its in learn mode press lock on your remote the door locks will cycle again to confirm that the keypad was registered turn the car off when done, then back to accessories to check it all worked
Current Mods 2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts Future Mods Lowerage on KingSprings Lows | Engine...Period | Sounds System I Use And Recommend F1 Tyres And Wheels On The Gold Coast Proud Supporter of Beat The Heat (NT)
Thanks mate your a gun.
Hi if you have 2 remotes do like they say then press each button on each remote in turn if you do them separatly one remote will cancel out the other and only one will work I know this from experience John
www.TUFFCARPARTS.com
Does anyone else have problems doing this?
Clearly I have some sort of issue that prevents me from successfully doing a procedure that thousands of others in Australia can, but NEVER have I successfully recoded any Ford remote in any Ford I've owned! What's wrong with me!
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
Hi the way Ive done it on half a dozen falcons EF and AU was this sit in the car turn the ign on turn off the radio and any other gear that runs off the key close all the doors and turn the key to the off possition then do this
1 turn the key to acc 2 press the demister button 3 times in quick sucsession the demist light should light up on the dash and the door locks will cycle "lock and unlock twice" 3 now push your door button on the remote while it is still in the ign on acc and the doors should unlock now do the same to the boot button on the remote and that should unlock 4 now remove the key and open the door and go outside and the buttons should lock and unlock the doors this works every time for me using second hand remotes hope this helps JOHN |
#7 | |||
Well I think this cheap car(read ex taxi) I bought has some issues? steps 1&2 all work as described but the remote will not learn(or the car's system)? and every now and again after doing the steps, with no luck, you turn off the key and it will instead of unlocking the doors jamb them locked, and I mean jamb you can't open them using the inside handle, which is a tad embarasing when your locked inside your own car? so the next question is if somebody knows where the "smart lock" brain is mounted? and can you get one from any AU and try and plugging it in? as I've got a nearly complete S1 front cut sitting in my back yard that I purchased from a local wrecker three weeks ago for another project I have underway, is the "smart lock" ecu the one that sits under the centre console towards the front? P.S. thanks to all who have replied so far to this thread you guys are guns! |
I was just looking at eBay at a couple of remotes there and had a thought is there a differance between S1>3 'cause I'm trying to program a S3 remote to an S1 car, could this be why it's not "learning"?
Hi Frank I didnt realise you had a series 3 remote my experience only covers series 1 and EF and EL the flat 2 button key pad with "smartlock' printed on it not the triangular shape ones sorry mate cant help there thanks John
Well if it's any consolation every thing that you said was spot on except that they won't interface, I was wondering on eBay there are a couple of flat remotes there and I noticed they only have 2 buttons on them so does that meen that with S1's they don't have a boot release on the remote?
Hi Frank your not having much luck are you.
Series one only have two buttons one for the boot and one for the doors (press once to lock press once again to open) they use the same button to lock and unlock the doors Hope this helps John |
#12 | ||
Well John I suppose luck is how you look at it, I'd say I've had good luck 'cause I've learned so much about these newer cars from this awesome thing called the internet (beats paying $800.00 for a workshop manual!) and I get to meet and interact with some great like minded guys who like me have a passion for the cars we drive & tinker with, u c this old bus I'm getting together is just a hack to drive to work & back my real project is my 90k S3 XR6 which I'm about to pull off the road and repower with a BF I6T motor! I'm nearly there with all the bits & pieces I need the olny major expence now it a WOLF ECU last week I got and fitted a FIBRE SPORTS carbon fibre bonnet with the B series bulge which looks real trick, this week I hope to finalise the exhaust manifold to the turbo( now that was a real head f--k) and once I get this old bus registered it'll be time to as they say "get the head down & the bum up" and start having some fun!!!!!!!!!!!
Frank. |
ROCKING THE EL FUTURA
so the same as an ed but instead of the boot button its the demister button.
#14 | ||
Hi monty not sure what you mean Ive never done an ED but if you mean AU or EF/EL yes you push the rear demister button 3 times
John |
#15 | ||
#16 | ||
I'ts not working on an AU 1 Fairmont Ghia, does this car have a different sequence?
#17 | ||
how do i program a eb fairmont remote
#18 | ||
Hi, I bought a 1998 au xr6 and it didnt come with remotes,i bought a second hand one from the wreckers.I followed your instructions but the locks only half cycle and stay locked untill the key is removed from the ignition and remote will not work.Any ideas or help would be greatly appreciated,cheers Mattman.
#19 | ||
meh.
![]() Join Date: Jul 2010
You've gotta press a button on the remote (doesn't matter wether doors or boot) once the doors have locked...
#20 | ||
What i mean is it only cycles to lock and doesnt unlock after pressing demist button 3 times.so pressing a button on the remote does nothing.
#21 | ||
meh.
yeah, it should lock after pressing the button 3 times...
Press a button, doors should unlock, then lock again. Then turn ignition off, car will unlock. Try the remote and see if it locks. If it doesn't work then, then it's probably the BCM
#22 | ||
Yeah i tried that but still no success,have to stick with just key i guess.Thanks for your help anyway.Cheers mattman.
#23 | ||
The one and only
I just did this and it worked for me.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#24 | ||
Worked for me but pushing the demister 3 times only locked the car then turned off the key to unlock then had to manually lock the car from the outside. After that it works fine
#25 | ||
I just want my remote to unlock "ALL" the doors at once instead of just the drivers door.
I gotta push the button a second time to unlock the rest of the doors. BTW Mines a series II
http://i56.tinypic.com/23hlk6p.jpg |
#26 | |||
#27 | |||
#28 | |||
I will try tomorrow ![]()
#29 | ||
had problems getting my falcon into programing mode was turning demist on and off 3 times.
where you have to PRESS DEMIST BUTTON 3 TIMES. Once i worked that out the rest was easy. |
#30 | ||
Yeah the 4 button remotes you need to put key in ignition and turn to accessories and within 5 seconds push on demister, then off then on again and wait for 5 seconds until the doors lock.
Then press the lock button on the remote and turn the ignition key off. |
