Old 23-09-2008, 05:32 PM   #1
simonr23
Default kh laser aircon problem
my gf has just bought a kh 1.6 laser. the aircon 'system' works it seems. i can hear the compressor actuate, the engine gets a bit more load on it and the a/c engine fan comes on. the problem is that there is no change in temperature, nor any de-humidifing. could it just be that it's out of gas? if so, i'd assume it's all leaked out for there to be no "aircon" effect happening. where should i be checking for leaks? any cheap things i can do to save a wasted regas?
thanks heaps.
simonr23 is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2008, 10:08 PM   #2
fairmont1998
fairmont1998's Avatar
Very possible that its low refrigerant that is the problem.
Best to take it to a mechanic to get that fixed, you can't just top them up yourself anymore.
If you are keen to look for a leak, start at all the pipe joins and use a soap solution. Wipe it over the joins and look for bubbles. (If the system is completely empty you won't see bubbles remember)
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2008, 09:32 PM   #3
Kariharnett
Lil Henry
Kariharnett's Avatar
most places put a dye in the system free of charge to find the leak, then they will charge you when they fix it and re gass it. but be carefull our mazda had die in the coolant to find a leak a long time ago and when they checked the a/c gas they found die all over the engine bay took them 3 weeks to figure out that it was coolant they could see not ac gas.
Kariharnett is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2008, 05:40 PM   #4
dirty hands
Over Thinker
dirty hands's Avatar
it could be the TX valve not working ( regulates the gas flow inside the car )
look for bubbles in the sight glass of the dryer (cylinder in engine bay )
My car goes Brumm Brumm
