Old 18-07-2007, 10:37 PM   #1
euroford
Default Oem Headunit
G'day focus fans just wondering if the original headunit in my 06 LS Focus has a control (signal) cable output for electronic antennas or amps your help is appreciated.
euroford is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2007, 11:38 PM   #2
melbzetec
Old enough to know better
melbzetec's Avatar
Black LS is your man
Old 19-07-2007, 12:34 AM   #3
BlackLS
You know your a forum junkie when people get reffered to me! lol
From what I've checked theres no signal wire for amps or electric antennas, nor are there RCA pre-outs.
Most people who have wired in amps with the stock unit have done so from tapping into the Accessory power cable going into the head unit. 0v when the car is off, 12v when key is turned to acc. Perfect
With getting a audio signal, either choose an amp with a high level input and feed the audio lines from the rear speakers into the amp, or if your amp only has RCA in's, get a high to low level line converter, tap into the speaker cable, then from the converter run RCAs to your amp.
Old 19-07-2007, 01:15 AM   #4
melbzetec
melbzetec's Avatar
And see. I was right !LOL
Old 19-07-2007, 09:39 AM   #5
photn
AFF Post NAZI
photn's Avatar
ROFL......
yes steve.. yes you where
Old 19-07-2007, 04:11 PM   #6
euroford
Thanks fellas for your help highly appreciated . I've purchased a BLAUPUNKT active bass reflex subwoofer which fits under either of the front seats, the instructions state that you can either use rca inputs or just tap into a left and right speaker wire, what had me shot was the control (signal) cable but now l understand what you mean run power lead from battery and signal cable to accesories on ignition.(got it)
Old 19-07-2007, 05:00 PM   #7
BlackLS
Where you located mr euroford
Old 19-07-2007, 06:16 PM   #8
euroford
melb southeast
Old 19-07-2007, 08:09 PM   #9
photn
AFF Post NAZI
photn's Avatar
LOL.......
BlackLS = sydney
Old 19-07-2007, 08:24 PM   #10
euroford
You guys would'nt happen to know the maximum depth of speakers l can use in the doors in an LS FOCUS the
