Hi ya i took the plugs out and clean them but i pulled the leads right out i dont know where they go back to FORD LASER K.C 1985 G.L
IS IT 1432 STARTING ON THE MARK ON THE DIZZIE THAT STROKE MARK AND GOING TOWARDS THE DRIVER WAY- IE FACING THE F/ WINDOW CLOCKWAYS SAY 1 AFTER THE STROKE 4 3 2 ALSO NOW I TAKE IT THAT ON THE LEFT SIDE OF THE MOTOR IS CL 4 THEN TO THE RIGHT 3 2 1 HELP GOT ANY PICTURES ITS MY 18 YEAR OLD SONS CAR AND DOES NOT KNOW ANY THING JUST HOW TO TURN THE KEY. HELP IAM DEAD AND I HAVE FLATEN THE BATREY TRYING TO GET THE PLUGS RIGHT WHERE IS CL 1 ON THE DIZZIE AFTER THAT STROKE MARK GOING CLOCKWISE YO MUMS HOME .....FFFFFFFF MITTSZE. HELP ![]() |
Over Thinker
first cylinder on compression stroke timing pully should be on TDC
1432 is most four cylinder engines take the cap off make sure the rotor is pointng on number one lead on the dissy cap then to the plug to get direction ---the next cylinder should be four to compress if not you are turning the engine the wrong way hope that helps
My car goes Brumm Brumm |
