Bseries Moderator
Hi,
im looking to build a cheap track only small car KF laser can fall into this category (also looking at 20v ae82, b16 civic). i would be starting with a cheap straight body and engine/gearbox would be replaced as will suspension breaks wheels and tyres im aiming about 200hp n/a or more i was wondering what motors could be slotted into the laser and how tuneable are they (aftermarket parts availability). b6 engine springs to mind but i know sfa about them could someone please educate me or point me into the direction of a source of info on them. cheers
Long Live the Rugerspeed Primer Destroyer! Only those that attempt the absurd achieve the impossible. Serviced and maintained by Mascot Auto Repairs
What a performer!
So you only want N/A? Ignore the B6 engines, the BP engines (1.8L DOHC EFI 92Kw @ fly) are solid and have huge potential if you have huge pockets. They also slot almost straight in as they come stock in the KF TX3's.
You'll also want the G Series gearbox from the KF TX3's, you won't have any problems being FWD. If you want to go forced (who wouldn't..) BPT's comes stock in the KF/KH TX3 4WD's and the engines are plentiful (117kW fly) BPD's come from the Mazda Familia GTR's (142kW fly) and they are the same as the BPT's apart from stronger internals/management/AFR .. There are KF TX3's running almost 300kW with these beasts. You will get a lot more information then I can provide at www.fordlaser.com ![]()
1981 Ford Laser KA :: E5 :: 2002-2003 1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW 1990 Ford Laser KF TX3 :: BP :: 2010-2011 1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW 2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW 1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020 2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-* 1998 Ford Falcon AU XR6 :: HP Intech :: 2021-* |
Bseries Moderator
hmmm it seems i will probably go with a corolla as i can get a ae101 front cut for >2500 that comes with a 20v blacktop (137kw n/a) ecu loom 5spd lsd box big front brakes and better suspension
throw that in a 1000 dollar corolla and i should be able to have some fun. ill check out that site and well see how i go
What a performer!
137kw N/A? Crazy! Good luck with it
