Hey everyone,
My key fob decided to quit, I opened it to and noticed one of the buttons broke off. Figured it would be a great idea to get a spare key and while on ali express I was faced with the options of what chip it is. Does anyone have a clue? Thanks!Screenshot_20220715-121407_AliExpress.jpgIMG-20220715-WA0002.jpg Sent from my SM-G998B using Tapatalk |
I think you need to buy a replacement key. I broke something in mine when I tried to change the battery, so I went to my local Ford Dealer in Epping "Bayfords" where I bought the new key, but then the new key had to be programmed within the service area. The key was cheap but the programming was around $170. This was around 6+ years ago, and I had Ford employee pricing so wouldn't know the cost now so you will need to talk to your nearest Ford Dealership
Hi, My key did the same. I soldered the micro switch back on. Worked fine. I had a spare key cut & programed by Morley Multi services in Perth. Western Australia. $90 for a flip key & programming.
From checking this website, it sounds like 40 bit is the original, but you can use 80
Chip ID: TEX 4D 63 (80-Bit - backwards compatible with 40 bit keys) I'm guessing once you replace the chip you'll be able to program it yourself using Forscan
Current: 2016 Camry 1966 Mustang Coupe Previous: 2011 SZ Territory Titanium 2008 Ford Edge AWD Limited Silhouette BF XR6, ZF Auto White EF GLi, XR look alike VH Commodore |
#5 | |||
Regular...with metamusal
![]() Join Date: Oct 2009
did they 'clone' the key tho? coz if it was it just means you have two the same ie. car views keys as same not different keys. |
