Requesting some advice re fitting an elect fuel pump to my 1600 engined mk1 esky.Car is used only about once a month ,has a 32/36 twin choke weber is the correct pressure a matter of concern ? What is best brand to fit?
Frankenford pilot
![]() ![]() Join Date: Feb 2008
I ran a small Facet fuel pump on a warm 2l Gemini for a few years, never ran out of fuel. Don’t recall the exact model but was only a small one.
Cheers Bretto 73 XB GT Last of the Big Ports ![]() |
RS The Faster Fords
![]() Join Date: Feb 2014
No need for an electric pump the factory unit will easily feed a pair of 45mm Webers.
Instead spend the money on a decent fuel pressure regulator, something like this... https://www.burtonpower.com/regulato...sefpr007g.html Webers thrive on correct pressure of about 2-3 psi and one of these will make a big difference in its operation. If you do decide to go for an electric pump make sure you also use a tachometric relay, these run from the ignition coil and cut power to the pump if there is no spark for example in the event of an major leak or accident. These are probably the cheapest and easiest way to go about it. https://www.ebay.com.au/itm/Brand-Ne...4AAOSwADtasHs8
REV8380
I would run an electric pump and regulator as suggested.
The electric pump when primed will supply fuel to start immediately saving the weak starter motors from trying to turn the engine over to get the fuel to the carby. This will also conserve your battery . I have done this on 2 of my cars with great results.
For Older Racing Drivers
2006 SY Turbo Territory - Dual Fuel, Debunged, F6 Lower Snorkel,Tune, 20"Rims and Pedders Suspension. Previous Ford Rides Tickford AU & SVO EA S/wagons - Dual Fuel Mk1 & M2 Escorts - modified 1969 Mk2 GT Cortina - very orginal. 1964/5 Mk1 GT Cortinas Group N Racing 1965 Mk1 Lotus Cortina Group N Racing 1964/5 Ford Mustang Group N Racing |
Might be worth a read.....
https://www.racetep.com/manufacturer...uel-pumps.html Top End Performance - Weber Specific Electric Fuel Pumps - Weber Carbs - Weber Carbs and TWM / Borla EFi Induction - Performance Brands* https://www.racetep.com/manufacturer...uel-pumps.html |
