I have a TF 4cyl 2.0 ltr diff (small type). It has a U bolt drive coupling. I hope to be able to swap this to a flange coupling from a TE large type diff. Can anyone tell me if the input shaft spline is the same size.
Thnx in advance, Roy |
[QUOTE=strrb;6487266]I have a TF 4cyl 2.0 ltr diff (small type). It has a U bolt drive coupling. I hope to be able to swap this to a flange coupling to suit my tailshaft. Can anyone tell me if the input shaft spline is the same size.
64 Deluxe 4 door
![]() Join Date: Jun 2007
I know TC/TD pinion splines are the same as I did a swap years ago in my old sports sedan.
I'd reckon it would be close. Bear in mind crush tube etc
XM Deluxe FG XR50 BA Pursuit Ute |
Thnx for the reply & info, it is very helpful & reassuring.
Roy |
