Hi guys and girls I was after a gear linkage cable for a 1972 ford capri auto and if anyone has one lying around that they don’t want anymore and it’s no seized or knows someone that would sell it that would be much appreciated as mine is seized and broken, I am located in western Sydney and can travel to pick up, I have attached my broken one for a reference and
Thanks for viewing my add 👌 |
#3 | |||
Thailand Specials
![]() Basically the length from where it mounts on a bracket to where it goes to the end of the threaded rod going into the fittings on the end. You may be able to use a hydraulic valve control cable if you can mcgyver something up, this will be the cheapest option: https://www.flexibledrive.com.au/sta...tcvaptckgv.pdf This place above has a handy little guide on choosing hydraulic valve control cables. Otherwise cable manufacturers such as Flexible Drive above or Control Connections could manufacture from sample as a custom job reusing parts from your busted sample there - but $$$. |
Flexidrive industries will make you a new one if they don't have one in stock , just take your old one in or if you cant then measure it and give them the specs
XC GS OLD SCHOOL MUSCLE ![]() Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
