Old 04-11-2018, 10:37 AM   #1
DAMO 58
Previously TUNGA
DAMO 58's Avatar
Default Au ute sports bar removal
I have to remove my tub liner to check the fuel pump sender unit as is shows empty when full , The bolts holding the sport bar on keep spinning
and won't undo ,
any clues would be great as car requires a RWC and can't get it with a dodgy fuel gauge
AU2 XR8 Pursuit Ute Liquid Silver
DAMO 58 is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2018, 11:31 AM   #2
PG2
#neuteredlyfe
PG2's Avatar
Default Re: Au ute sport at removal
and won't undo ,
The nuts used to hold the sports bar are not captive. You will need to get a spanner up under the inner guards to hold the nut. You will also need to do this for the nuts at the front of the tub as well.
Old 04-11-2018, 11:57 AM   #3
DAMO 58
Previously TUNGA
DAMO 58's Avatar
Thankyou I will try to make a tool up to get behind the cab
Old 04-11-2018, 12:30 PM   #4
Tassie f100
and won't undo ,
What has a fuel guage got to do with a roadwothy certificate??
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2018, 01:01 PM   #5
DAMO 58
Previously TUNGA
DAMO 58's Avatar
I agree but I was no go as it is
Old 04-11-2018, 03:16 PM   #6
superroo
You can't stop the signal
superroo's Avatar
Just taking the tub liner out won't give you access to the fuel pump.
You will be able to drill out spot welds that hold the tray floor down though.
https://fordforums.com.au/showthread.php?t=11313390
Old 05-11-2018, 10:26 AM   #7
DAMO 58
Previously TUNGA
DAMO 58's Avatar
Default Re: Au ute sports bar removal
Thanks for the help ,it's a lot of work to get a fuel gauge working now considering selling without a RWC
Old 06-11-2018, 07:30 PM   #8
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
Or try a normal workshop that won't pick on fuel gauge for RWC.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
