Ford Performance Club of ACT Club Discussions General Chit and so forth! |
Hi all, i thought i'd share a little story with you all about our little XR8...
It was bought almost 3 months ago, we got it for $23,000, (its also a 5 speed) which i thought was ok... the 1st test drive there was a tap in the engine i was told it was a lifter problem and it would be fixed before we took delivery, so i thought no worries and signed on the dotted line. 2 weeks later we were able to pick it, as it was in the workshop for those 2 weeks, picked it up and it still made the same noises, i was told that the "NEW" lifters had to wear in and would stop making noise after about 500k's, me being not too smart with engines believed what i was told. I picked my father up from the airport the next day(he used to be a mechanic), he then filled me in on what is the truth about my car, lifters dont need to be run they are quiet from the start! the lifters hadn't been touched.. So.. it went back to the workshop.. it then spent 2 weeks at ford, now it was thought that it could be the timing chain and adjusters. they were replaced and yet the engine still tapped! they filled it with lifter free up, thinking again that must be the problem, i got it back and was told if it still tapped after 500k's they'll pull the motor apart. It went back of course, after a week they found it was the big end bearing! And my clutch is on its way out. (it feels fine to me?) This is were my luck kinda changes for the good, i ended up with a completely new bottom end, the heads were reconditioned so on and so forth, my motor is now pretty much brand new with only 590k's under its belt. But it did spend just over 2 months in the shop! Im slowly running it in, i tell ya its hard not to put my boot to the floor, since the i bought it i haven't been able to see what it can do. So just when i think all is good, my rear back door lock actuator craps itself, my drivers door electric window motor craps itself and my cd stacker is player up with disc slot 2 & i need to get my after market pod gauges re-wired... Luckily everything is covered under warranty. (except the gauges) Well i hope this didn't bore to many people i just had to tell someone my story. We'll see you all on the next run, hopefully my car will have all problems fixed. Cheers ADAM. ![]()
BA XR8 | SILHOUETTE | 5 SPEED | DI FILIPPO HEADERS & CATS | CUSTOM 3" EXHAUST | TEX CLUTCH | 20'S | LOWERED BY PEDDERS | CUSTOM TINT | BOOT INSTALL Tint UR Ride
www.tinturride.com.au |
FGII XR6, Focus Sport, XR
Damn, I bought my Manual XR8 for about $21,000 and it's been nearly perfect. Only a few minor easily fixable problems.
Bad luck there Adam. Hope all goes well from now on.
Living Ford dreams
2011 Purple FGII XR6 2016 LZ Focus Sport BA XR8 Build Thread (SOLD) 1966 XR Falcon Build Thread |
Hey adam...i'm a member of the newcastle club but haven't met you yet...I used to drag race and build cleveland race engines for street and strip and the street engines i used to tell my customers with the street engines to take it easy throught the rev range of up to about 4 thousand revs and when they got to 500k's bring it back, i used to change the oil retighten everything re torque the heads re tune the engine and from then on they could drive it how they liked....i used to spin my street cleveland motor to 7 thousand revs and never had a problem....so if you have done 590 k's drive it like you stole it and as them telling you the lifters had to be run in, fair dinkum, ya sure they were ford mechanics and no the apprentice.....lol......cheers mate and catch ya on a run........cheers Mick!!! :jab:
Merry Xmas To All
I like how they say it's a lifter..... On a boss?
#5 | |||
So i should be able to swap my rear mags for stocky's hey? :evil3:
How many kms had the car done to require that kind of work?...Although you're happy, I'd be ****ed I was lied to about the lifters being replaced in the first instance...A clutch should be good for at least 100k kms
2005 BA MK2 FPV GT - 6 SPEED MANUAL , SILHOUETTE, SWISSVAX, SUNROOF, BILSTEIN AND LOVELLS, FACTORY GENUINE 19'S, X-FORCE STAINLESS QUAD CATBACK, ADVANCE HEADERS, 200 CPSI CATS, BLUEPOWER CAI, HERROD BREATHER KIT, 4:11 DIFF RATIO, MAL WOOD OPT 3+ CLUTCH, BILLET SHIFTER, MELLINGS 10227, NOW WITH REVERSE CAMERA/SENSORS, ALPINE SPEAKERS & SUB - CUSTOM TUNED TO 275 RWKW NOW WITH A NEW ADDITION - 2017 MUSTANG V8 GT FASTBACK - , 6 SPEED AUTO IN PLATINUM WHITE, |
#7 | |||
#8 | |||
BOSS 5.4L Enthusiast
KillerXR8
![]() Join Date: Feb 2007
only problem I have ever had with my 04 XR8 is the door lock actuators and the bam module in the dash that runs the door locks,otherwise touch wood she's perfect and about to clock over the big 100,000k's in about 800ks time.Only had 60,000 on it when I got it...lol...had it for just over 2 years.Good luck with your car now Adam....
FULL X-FORCE STAINLESS EXHAUST,HERROD HP CAMS,YELLA TERRA PLENUM, GT 500 TWIN 60MM THROTTLE BODY,GT AIRBOX,K&N FILTER,ZF TUNE,CUSTOM TUNE,8" BOSTON ACCOUSTIC SUB,SONY AMP,AUTO METER D-PIC GAUGE,INNOVATE WIDEBAND AFR GAUGE,CUSTOM GAUGE HOLDER FROM STAV AT STINGRAY, KINGS SUPER LOWS,20 x 8 FPV DARK ARGENT REPLICA'S,BLACK TINT,CUSTOM MATT BLACK DECALS 2009 TWEEKD FG XR8 IN SILHOUETTE all mods done by Walter Markham from Oztek Performance
LIfters on an overhead cam engine ? Must be a new design . LOL
Cheers GT450 |
#11 | |||
Whipple Induced
Hi Adam
I hate reading stories like this. They may as well have told you the sound was coming from your automatic transmission! Regardless, I’m glad to hear the motor has been rebuilt. Do you know if they just did a re-ring and bearing job? I would imagine so but at least that's better than a ticky engine. Buying a performance car that has bold tyres can tell you a lot about how it's been treated. Anyone who actually loved their car and cared about its maintenance would not drive it around with tyres like that. Personally I would get as many things under warranty fixed as you can. If your still not 100% confident in the car then sell it and get yourself another one (or an 03 GT) that is in better starting condition mechanically. These cars are great when they are working but are very expensive to fix for a young owner. Best of luck Colville
#12 | |||
#13 | ||
Adam.
Sad to hear, so far I've had a good run out of mine, 117,000kms & only the usual Timing Chain noise when cold. Have ya had it over 3500rpm yet? Thats where the fun begins & its very addictive!
2004 BA XR8, Winter White, Manual, 20's, Bluepower Custom Tune, Difilippo Extractors, etc - 241.4rwkw Build Thread SOLD ![]() 2007 BF Mk2 Winter White E-Gas Wagon, 6 Seater. 2002 AU3 XR6, Liquid Silver, Manual, Sunroof, LPG, Rebel Kit, BA GTP's, Momo Steering Wheel & Gear Knob. |
#14 | |||
:eclipsee_
#15 | ||
LIKE A BOSS 351
This story says more about the quality of repairs than the quality of the car.
#16 | |||
![]() Join Date: Jan 2005
#17 | |||
Praise da lord,Henry Ford
#18 | ||
I think the message is ONLY BUY FROM A REPUTABLE FORD DEALER.
