Old 02-09-2006, 11:08 AM   #181
JeffAU1
JeffAU1's Avatar
Also after the following items, part numbers and costings if you have them please
Chrome Door Handles - Inside (To fit AU Series 1) (Each or pair or set of 4)
Chrome Button for Auto T-Bar (To fit AU Series 1)
Chrome Button for Handbrake (To fit AU Series 1)
Thanks again
:eclipsee_ MY CAR :eclipsee_
JeffAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2006, 12:07 PM   #182
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Originally Posted by JeffAU1
Hey Russ
Whats the part number for the AU Series 1 Mudflaps
Does the part come with all screws etc needed, or are they seperate, and if seperate what item numbers
Jeff
ER 16360 A KIT - MUDFLAP - REAR, LESS BODY STYLING KIT $32.40
AU2 16360 A KIT - MUDFLAP - REAR, LESS BODY STYLING KIT, 4 DR SED $33.80
AU2 16360 KT KIT - MUDFLAP - REAR, WITH SIDE SKIRTS, LESS XR BODY KIT, 4 DR SED, (-)XR $31.30
ER 16268 A KIT - MUDFLAP, LESS BODY STYLING KIT, FRONT $31.10
AU3 16268 KTA KIT - MUDFLAP, WITH SIDE SKIRTS, LESS XR BODY KIT, FRONT, 4 DR SED, (-)XR $33.80
These are kits and come complete with all mounting hardware.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2006, 12:11 PM   #183
russellw
russellw's Avatar
Thanks again
The article HERE in our tech section has all the AU trim bits listed.
Russ
Old 02-09-2006, 01:04 PM   #184
JeffAU1
JeffAU1's Avatar
Russ
Do you know which one I would use for a AU1 Future Sedan, No body Kit ?
Old 02-09-2006, 01:04 PM   #185
JeffAU1
JeffAU1's Avatar
Russ
WOW thanks
Old 02-09-2006, 09:25 PM   #186
russellw
russellw's Avatar
The very first one in each set - the ones that start ER.
Russ
Old 03-09-2006, 12:26 AM   #187
JeffAU1
JeffAU1's Avatar
Russ
Sorry Russ, but im not that clever with cars.
In the below pic is both the t-bar shifter and the handbrake lever, both with the silver button, (Yes i have circled these to make sure i am explaining myself correctly) and i need them in the same colour as the interior of my car
The link you gave me shows the handbrake as:
AU Leather Handbrake:
ER 2760 B6 about $200 plus the boot.
But i dont know if this is the right one, and in the right colour... also i could nto find the correct t-bar with chrome button
thanks again
Old 03-09-2006, 08:50 AM   #188
Crash Lander
I had DL LTD once and had to replace the leather T-bar auto handle. Cost me $300!! They nfitted slightly the wrong colour, so I made them change it.
Some people think I suffer from A.D.D., but they... Oh LOOK! A Chicken!
Crash Lander is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2006, 09:31 AM   #189
JeffAU1
JeffAU1's Avatar
But the interior is the one thing i dislike about my car, so i think its $300 well spent
Old 06-09-2006, 12:02 AM   #190
JeffAU1
JeffAU1's Avatar
Russell,
Whats the part number/cost for a AU Left Electric Door Mirror with Glass/Cap ?
Old 07-09-2006, 12:44 AM   #191
russellw
russellw's Avatar
Russell,
BA 17683 DP MIRROR HEAD - EXTERIOR REAR VIEW, LH, PAINT TO SUIT, $150.00
If you want the individual bits then use the Parts Database Search Tool and search under mirror.
Russ
Old 12-09-2006, 06:59 PM   #192
xr6vct1999
Default clutch
Hi russellw !
I have AU 1999 xr6 vct 5sp
I was told today i need new clutch and asked how much was told $1400 fitted. My reaction was am geting new car for that price. My question the f3zz7563a is that the right one i assume it is ford part number and price? Is there an aftermarket kit that could be used ?
cheers
xr6vct1999 is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2006, 07:26 PM   #193
russellw
russellw's Avatar
I would have thought the relevant bits were these ones:
EDTVE 7563 A PLATE CLUTCH PRESS, (4.0L SOHC EFI 6 CYL (VCT) 5 SPEED MANUAL (T5) OR 4.0L SOHC EFI 6 CYL (HP) 5 SPEED MANUAL (T5)) 537.00
Not sure which actual clutch plate.
The F3ZZ unit is also a pressure plate plate but I suspect it's a V8 one.
Old 12-09-2006, 07:45 PM   #194
xr6vct1999
Thanks for your reply. Look i realy have no idea as F3ZZ was the most expensive i thought it could be it. And to confirm these are ford part numbers and prices is it gst inclusive?
Thanks for your help.
Old 12-09-2006, 07:56 PM   #195
russellw
russellw's Avatar
These are Ford part numbers - prices were correct last December when we created the DB but they won'tr be now inevitably.
Russ
Old 13-09-2006, 02:20 AM   #196
Mechan1k
Mechan1k's Avatar
thanks again
It should be that grey colour ... I have the handbrake and boot with chrome button sitting at home ready to swap in ... only problem is .... I need to pull the driver's seat out to swap it over (it's the only way to do it too).
handbrake and boot was over $200 from memory ... as the handbrake is the entire ratchet mechanism as well with cable to mount under the floor of the car.
Old 13-09-2006, 02:44 PM   #197
xr6vct1999
russellw thanks it is much appreciated. Yes the prices must heve gone up as the $ 1400 was ford service workshop price. I asked the guy how much if i supply the clutch he sad just labor and machining of the fly wheel $ 580 so that leaves $ 820 for clutch.
Thanks
Old 22-11-2006, 12:33 AM   #198
Funtime25
Funtime25's Avatar
I am after the rear boot badge that is located in the centre of the rear boot lid for a LTD AUII
Funtime25 is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 12:59 AM   #199
russellw
russellw's Avatar
It appears to be obsolete.
The BA one is BL F42528 A NAME PLATE, LTD, LTD
Russ
Old 25-12-2006, 01:28 PM   #200
Duffman
Oh Yeah!
hay russel you wouldn't happen to know how much a headlight switch would be? Just the standard black one in the forte... mine is broken :( thanks
Oh no! Duffman can't breath! Oh, yeah!
Duffman is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2006, 01:46 PM   #201
russellw
russellw's Avatar
All of about $11 or so.
AU 11666 A
Russ
Old 24-01-2007, 11:23 PM   #202
Duffman
Oh Yeah!
Thanks Russell. For anyone interested the head light switch (all of it) that plugs into the loom costs $48 from ford.
Old 14-03-2007, 10:11 PM   #203
phibza_XR6
drive it like u stole it
phibza_XR6's Avatar
hey, just wondering does anyone happen to no if the fuel tank sender unit in
the sedan is the same in the utes.
phibza_XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2007, 10:49 AM   #204
Chippar
The Ancient Warrior
Chippar's Avatar
Mate, I've checked everywhere and everywhich way but I can't find any info on an AU Falcon Drive Belt/Serpentine Belt e.g. part No. or price. What am I doing wrong or isn't it listed?
Chippy..
Chippar is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2007, 11:31 PM   #205
russellw
russellw's Avatar
Chippy..
AJK6 956 BELT, 4.0L SOHC EFI 6 CYL (VCT) $65.80 AJK6 995 BELT, (4.0L SOHC EFI 6 CYL (MP) OR 4.0L SOHC EFI 6 CYL LPG OR 4.0L SOHC EFI 6 CYL (HP)) $46.00
Russ
Old 17-03-2007, 11:07 AM   #206
Chippar
The Ancient Warrior
Chippar's Avatar
Russ
Thanks for that Russ.
Chippy..
Old 05-04-2007, 02:20 PM   #207
Grechie
Grechie's Avatar
Hey guys...
using the parts database, it failed for me, i was just wondering if you's could tell me what this AU Falcon part number is from :
WR2T-12A650-HB
- Grechie
2015 FGX XR8 - 557rwkw on E85
KPM Street Fighter
PCMTec
Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19
Shockworks Coilovers
PITLANE AUTOMOTIVE & PERFORMANCE
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2007, 07:30 PM   #208
russellw
russellw's Avatar
Originally Posted by Grechie
Hey guys...
WR2T-12A650-HB
- Grechie
The number should be RWR2T 12A650 = all of which series are ECU modules but I don't have an HB listed.
Russ
Old 07-06-2007, 07:40 PM   #209
namecrap
hi can u tell me what series au this ecu is from wr2a-12a650-cd
cheers
namecrap is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2007, 10:51 PM   #210
russellw
russellw's Avatar
The prefix is incorrect but the 12A650 CD is from a 5 litre 200 kW T-Series with 4 speed auto so therefore it is a T1, TE50.
Russ
