Old 07-05-2007, 11:19 AM   #121
dirty hands
Over Thinker
dirty hands's Avatar
already been to two mechanics and they dont know - great
if its a carby the fault will be there or spark from the coil to the plugs
notwhere else it can be
recheck timing and for cracks in dissy cap
clogged catalytic converter-- yes if the engine has been burning a lot of oil - you can take the system apart and check to see if its clogged badly
go to the tail pipe and see how much pressure is comming out the back should be eneough to move your relaxed fingers
My car goes Brumm Brumm
Old 09-05-2007, 08:37 PM   #122
rustbucket
Default 2up
howdy y'all
i've recently purchased a 1985? AS auto telstar GHIA, it did have the same problem as carnewbie's (not idling etc) and i found the problem to be loose/disconnected vacuum hoses, probably best to check all vacuum hoses you can readily see for any loose connection; also they age poorly and may have cracked.
cheers!
rustbucket is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2007, 11:15 PM   #123
dirty hands
Over Thinker
good thanks for the input and feed back
Old 13-05-2007, 11:19 AM   #124
rustbucket
Default rust aint the problem
all is well with my 85 telstar ghia... apart from the clunking noise when I turn left, at low speed it is only apparent on sharp/tight corners, however at higher speeds (100kph) it does not take too much of a bend to invoke a clunking noise, which i think is coming from the LHS
could this be the CV joints? (please no!!)
anyone had a similar problem?
cheers
from now on, i'm turning right!
Old 13-05-2007, 02:32 PM   #125
dirty hands
Over Thinker
yes its the cv joints
all about CV joints
Part one general information
http://www.aa1car.com/library/cvjoint1.htm
Part two faults and diagnosis
http://www.aa1car.com/library/cvjoint2.htm
Old 13-05-2007, 05:37 PM   #126
fordford
Im repairing my mrs 86 kc laser. As far as i understand the std ign. timing is 2 deg. +- 1
I did it the slack way and didnt remove the v belt pulley. Im trying to use the v belt timing mark to get the motor back to tdc. Before i put the head back on a mate and i set the piston to what we thought was tdc (piston at the top)
Have u got any info on setting the timing, or getting tdc on these 1.6 motors (with me being slack in this case and not removing the v belt pulley) to make sure i can get it to tdc?
Thanks.
fordford is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2007, 07:27 PM   #127
dirty hands
Over Thinker
the person who is the guru on lasers is vippin you need to pm him
I havent worked on the laser engines in a long time and dont want to give you wrong information
for the 4 cyl put the timing pully back on and rotate the crank to tdc mark
at TDC the cam shaft has to have the number one cyl with both valves closed up
and number 4cyl rocking so exhaust or inlet is about to open
Old 13-05-2007, 11:19 PM   #128
dirty hands
Over Thinker
there is a picture now on the laser post for you to follow
http://www.fordforums.com.au/showthread.php?t=99614
Old 07-06-2007, 02:53 PM   #129
torqueischeap
Hi
Yesterday I got a 1985 AR 2.0l telstar. I used to have an '86 AS so i know the basics around it and that they are a pretty bullet proof car. Anyway this one was overheated and i got it for free as the owners figured it was a blown head gasket so wanted rid. Any way i towed it home and i cant get it to start.
Have tryed jumping it and altho when its connected all the dash lights come on when i turn the key to start nothing happens. No click from the soleinoid or anything... the soleinoid has all wires in place but i cant get it to even look like turning over. the ppl i got it from said apart from the flat battery and the overheating it was running fine...
anyone know what i should look for, at this stage i figure i may have to replace the starter... unless there is a blown fuse i should be looking for?
PS its not seized up cos i can turn it over by hand
torqueischeap is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2007, 04:30 PM   #130
dirty hands
Over Thinker
jumping the battery may not be good eneough
put a good battery in the car clean the terminals use metal bolt on battery terminals if not already fitted clean of the corrrosion
check that the earth is good to the chassis
now if that has been done take the plugs out
if the the starter wont work
the solenoid may have failed, brushes or the plastic ring gear internally
head gasket
there now maybe rust or water in the cylinders and plugs may not fire
something else to deal with
Old 07-06-2007, 05:44 PM   #131
torqueischeap
thanks....i tried the battery out of my car and still nothing... no sound at all... not sure how checking the pugs would help the no cranking thing tho??
im pretty sure it must be the solenoid or the starter as it makes no sound at all on start.
Once I can get it cranking then ill start worrying about the other problems lol
Thanks muchly
Old 08-06-2007, 07:48 AM   #132
dirty hands
Over Thinker
taking the plugs out gives the starter no compression to fight against
thats all ......... yep the starter has to come out
Old 09-06-2007, 06:19 PM   #133
Timaeeee
Hey guys, I'm looking to change the oil and filter (and maybe more) on my Gfs TX5 2.0ltr carby (89 I think). Motors done over 300,000kms, bit tired but thought it couldn't hurt.
1. I got some Castrol GTX2 20w-50, and a Ryco Z56B filter, sound good? 3.9ltrs of oil with filter change right?
2. I might also do the plugs and maybe the leads, suggestions on brands, preferably with model numbers? I looked up the NGK site, BP5ES-11 plugs ok?
3. Are the plugs and leads tricky to change? I've done it on my Skyline plenty of times, never on a FWD car though.
Cheers,
Tim
Timaeeee is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2007, 12:11 AM   #134
dirty hands
Over Thinker
all what you have there is good
no need to change your list it is a carby model so no problem
the plugs - just use the right plug spanner and dont overtighten on a alloy head
dont get the firing order of the leads mixed up and remember the plug gap should be on the packet of 4 or in the cattle dog
Old 26-06-2007, 11:50 PM   #135
Fordfreak876
hey i was just wondering if you or anyone could help with my 87 Ford meteor? its a hunk of just but im wanting to do some small upgrades like new pistons n that sort of stuff...ne help?
Fordfreak876 is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2007, 09:10 AM   #136
dirty hands
Over Thinker
need to strip the motor down
see if it requires a rebore
or if you can just re ring and bearings
std /oversize pistons/rings/bearigs + full rebuild gasket set /timing chain
avail from from repco supercheap or other
if too expensive a sec hand engine from a wrecker
ring around for quotes and best parts cost per item .. then off you go
look at the gearbox and drive shafts while at it
Old 13-07-2007, 06:33 PM   #137
dirty hands
Over Thinker
timing belt for the 2 ltr telstar
Old 15-07-2007, 12:48 PM   #138
finmac
Default 84 Telstar Wiring
Im currently installing a new head unit in my 84 telstar. Does anyone know what each colour is?
Iv got;
Green
Green/Black
Black
Blue/White
Grey
Grey/Black
Aerial plug and a ground
Can anyone help?
finmac is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2007, 02:21 PM   #139
finmac
Default Wiring '84 telstar radio
Iv got;
Green
Green/Black
Black
Blue/White
Grey
Grey/Black
Can anyone help?
I have looked at it again i have narrowed it down to
Blue/Black
Blue/White
Red/Black
Need to know which one are the permanant live, ignition live and the illumination colours..
Old 16-07-2007, 12:52 AM   #140
dirty hands
Over Thinker
ford were not forth coming with that info you will need a test light to find the power wire and then after the earth is found the rest would be speakers
a previous post
Meanbow the good welsh lad
just finished stripping off the panels on his '83 Telstar and reviewed the wiring he did and this is what he came up with,
Meanbow always says
use a multimeter/circuit tester as well to confirm the correct wiring
Telstar(GC/GD Platform) radio wiring
Light Green - Permenant live
Dark Green - Ignition live
Red/Green stripe - night illumination(light circuit)
Black - Ground/Earth
Speakers
Front right
Blue/Brown - Negative
Blue/Brown with Green - Positive
Front left
Blue/Brown with Orange - Positive
Rear right
Blue/Brown with Red - Positive
Rear left
Blue/Brown with White - Positive
Old 16-07-2007, 08:01 PM   #141
finmac
Thanks mate all good
Old 19-08-2007, 11:54 PM   #142
dirty hands
Over Thinker
where did the information end up
think I lost some links or posts
hope I can have more than 6 pages or
I will have to start up a info post section 2 :
Old 02-10-2007, 10:09 PM   #143
dirty hands
Over Thinker
Default back to page one
back to page one
bump cause I dont have a sticky :
Old 11-11-2007, 03:42 PM   #144
dirty hands
Over Thinker
back to page one
Old 14-11-2007, 04:10 PM   #145
frdgrl
g'day i had the same prob with my 1990 EA. it had to have the dash ripped out and was sent to sydney for analysis. get ur auto elec to test the computer behind ur speedo, it may be faulty, after 17 years, that was the prob wit mine.
frdgrl is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2007, 04:23 PM   #146
sturty_tx5
elmo
hey mate i just bought a 1990 ford telstar ghia with a 2.2L sohc fuel injected motor and wanted to know if it was possible to convert in to twin cam? cheers
sturty_tx5 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2007, 07:01 PM   #147
dirty hands
Over Thinker
Thumbs up
yes just find a ford friendly engineer for the modification certificate
I would think you need the whole twin cam motor
and the engine computer controller
so that may need a wiring loom and a bit more work
engine mounts/ gearbox/driveshafts/brakes info I dont know about
Old 15-11-2007, 12:12 PM   #148
sturty_tx5
elmo
would it be possible to just swap the head for a twin cam off another f series motor, if yes which motor could i use? maybe the fe3
Old 15-11-2007, 04:49 PM   #149
dirty hands
Over Thinker
dont know the answer -
try this forum
http://z3.invisionfree.com/tx5/index.php?
or ask a ford wrecker or engine rebuilder
Old 16-11-2007, 06:08 PM   #150
gwak2007
Piston Broke
gwak2007's Avatar
Any ideas on fuel economy for KA Laser 1.3 ltr Dirty??
I'm getting about 400km city driving from a full tank.
gwak2007 is offline   Reply With Quote Multi-Quote with this Post
