Old 01-11-2006, 09:48 PM   #91
dirty hands
Over Thinker
dirty hands's Avatar
a kickdown band adjustment may still be needed
not able to undo the locknut could mean anything -- even a new kickdown band replacement
now in the hands of the automatic workshop
I found this group of automatic shops good--- but there are others
http://www.allstatestrans.com.au/locations.htm
only other thing it may be if an EFI -- is the throttle position sensor at the throttle body
a diagnostic run on the transmission control unit of your car should pick up any electronic management fault
My car goes Brumm Brumm
Old 01-11-2006, 10:06 PM   #92
AutoTX5
I was not able to remove the locknut because you had to hold the adjuster, a 1/4 inch bolt while undoing the locknut that was probably set to higher than 34Nm (spec). Too hard under a set of car ramps and probably the wrong set of tools.
Yep- throttle position sensor is at the throttle body.
Its on the way to the auto workshop now.
AutoTX5 is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2006, 02:16 PM   #93
dirty hands
Over Thinker
this one
Old 16-12-2006, 09:53 PM   #94
dirty hands
Over Thinker
meanbow is your car running great now
Old 19-12-2006, 05:40 AM   #95
meanbow
Welsh...and proud
meanbow's Avatar
Thumbs up
4: My car's running just fine now dirty hands.many thanks for asking.
it's just so hard getting parts for a car from austrailia thats not meant for the U.K,espescially as i've been told by the austrailian ford owners club uk that it's the only one they know of IN this country...at least i have a sympathetic motor factors who helps me get service parts...
meanbow is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2006, 01:15 PM   #96
dirty hands
Over Thinker
good thing the telstars are reliable
Old 19-12-2006, 01:18 PM   #97
GRNKPR
DPC PERFORMANCE Race prep
GRNKPR's Avatar
free advice again sell it !!!!!!!!!!!!!!!!!!!!!!!!AARRRGGGGGGHHHHHHHHHHHHH im a little pirate now
: : i will excell with the knowledge i get on here : :
FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria
Ford Performance Car ClubFord Performance Car ClubFord Performance Car ClubFord Performance Car Club
GRNKPR is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2006, 03:10 PM   #98
meanbow
Welsh...and proud
meanbow's Avatar
Talking
i'll sell it when i've made my first million and can afford to buy a bentley with CASH, or when pigs start flying....whichevers soonest.
even then, i'd still keep it...just to have it all pimped out : ...lambo door conversion, hydraulics, spinner rims,bootful of I.C.E,etc :sm_drool:
Old 22-12-2006, 08:50 PM   #99
dirty hands
Over Thinker
cental locking , a pimp out ,
wonder what the car is worth if it is the only one of a kind in wales or in britan
Old 23-12-2006, 12:03 PM   #100
meanbow
Welsh...and proud
meanbow's Avatar
Smile
who knows?
it cost me £120(around $60au)...and people have offered me NOTHING for it, and i'm quite sure if i Ebay'd it, id just about get a little more than nothing for it,even though i've managed a partial restore on it...it's the age, all 23 years of it
central locking's a pimp out?
excellent...i'm well on my way towards my vision now then... :disco:
Old 23-12-2006, 12:14 PM   #101
meanbow
Welsh...and proud
meanbow's Avatar
here's a video of a few lowriders in my local area...this is what i wanna make my Telstar do... :hihi:
http://www.youtube.com/watch?v=GIG1O6640OY
Old 23-12-2006, 01:58 PM   #102
dirty hands
Over Thinker
sure it needs hydraulic suspension and the hydraulic fluid controllers/switches and pumps ...with a boot full of batteries
some cars use computer programms thats going to be one kewl car meanbow
Old 15-01-2007, 05:28 PM   #103
Typhoon WR
Thinking of buying this. What should I check?
http://carpoint.com.au/used-car/FORD...a/2258650.aspx
should I chcken out?
Thanks
Typhoon WR is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 07:33 PM   #104
dirty hands
Over Thinker
it is in the right price bracket
unless you know a lot about turbos I wouldn 't buy one
two sites do a lot of homework about the ford turbo (not cheap to fix )
http://www.mx6.com /forums
http://z3.invisionfree.com/tx5/index.php?
with the turbo if there is an internal fault you wont know till its too late
head gasket problems and cooling
cv joints and gearbox noises
Old 17-01-2007, 11:16 AM   #105
meanbow
Welsh...and proud
meanbow's Avatar
Angry
uhh, hi all.
not looking for any help or anything this time..just being the bearer of bad news unfortunatly.
my Telstar is being sold on to a collector of unusual/unique cars here in wales, so you may not see me around here much from now on, as i have bought another car(luckily it's still a ford, a Mk VI Escort TDi)
i'd like to thank everyone who helped me with my problems, especially dirty hands...the resident Telstar guru :king:
thanks again...i'll still pop by every now and again :lookedat:
STOP LOOKING AT ME....I DIDN'T HAVE A CHOICE!
the girlfriend made me do it...
Old 17-01-2007, 01:32 PM   #106
dirty hands
Over Thinker
yep dont be a stranger - I was thinking because it was a rare car you would sell it
been a pleasure drop in with the knowlage you learnt I am in the escorts as welll
had mk1 and 2s see you around meanbow
Old 25-01-2007, 04:54 PM   #107
dirty hands
Over Thinker
Default head gasket blown/head removal
head removal and timing belt info should be in amoung the posts in here if not I will make a how to do
elec spec valve adj and timing belt page 1
put timing on TDC num 1 cyl up on compression
do not turn engine over from this time until head is refitted
drain coolant
drain oil
undo rocker cover
undo cam belt cover and mark the belt and one cam tooth with nail polish
so you know where to refit the belt and the cam
undo cam gear and rockers
undo all wiring and hoses /fuel lines and mark vacuume lines from where they came
remove dissy
undo head bolts
remove head clean gasket surfaces and check for warpage
get head done by head reconditioner and a pressure test for cracks and a reface///get valves checked and new valve stem seals fitted
check block for warpage
fit new gasket torque to spec
fit new gaskets as required
reconnect everything fit dissy and timing belt to the same position as before
fill radiator and oil to engine
Old 16-02-2007, 08:16 AM   #108
dirty hands
Over Thinker
head bolts cold -88 nm
rocker cover bolts 4 nm
manifold exhaust 29nm and inlet 26 nm
rocker gear 27 nm
timing belt cover -10 nm
crank pully bolt 120 nm
camshaft sprocket nut 66 nm
vales inlet and exhaust 0.33
firing order 1342
timing 6 degrees disconnected vacume line
valve settings rotate engine clockwise with num 4 cyl on rock
adjust numb ones valves and go from there
two rocking do threes valves
one rocking do 4 s valves
3 rocking do 2s valves
Old 16-02-2007, 11:29 AM   #109
GRNKPR
GRNKPR's Avatar
Thumbs up
: : then why have you got dirty hands : : ??????????????????????????????????
Old 16-02-2007, 03:23 PM   #110
eb_5litre
It'll Buff Out.
Ok my starter motor is dead and i'll most likely just grab a reco'd one from the autoleccy. Any tricks to pulling it out or is it straight forward?
eb_5litre is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 08:51 PM   #111
dirty hands
Over Thinker
straight forward just the bolts as usuall
dirty hands because all i do is work on other cars for fun :
Old 02-03-2007, 03:57 PM   #112
dirty hands
Over Thinker
for questions about TX5 made after 87 please try www.telstarperformance.co.nr
still dont understand turbos or conversions
Old 06-04-2007, 05:09 PM   #113
eb_5litre
It'll Buff Out.
Ok so yesterday my passenger front power window crapped itself nearly fully open..... its pouring rain now so how do I get the mongrel up ??? Ive cleaned and tested the switch and its not that. I then pulled the doortrim off and tried to power the motor directly..... nothing, it just ticks.
Surely there is a way to manually close the window until I get a chance to replace the motor?????
P.S. Does anyone have a spare motor for sale??
BTW Its a 1985 AS TX5 Turbo..... with a fully sick gladwrap window.
Old 06-04-2007, 08:16 PM   #114
dirty hands
Over Thinker
If you are lucky you may be able to get to the screws holding the motor onto the lifting frame (to undo )
If not you may have to drill holes in the door skin to reach the screws to release the motor...then you can push the window closed and try a stick to keep it up from inside the door skin
see if there is more helpfull info-- part ---- mazda/ford wrecker
need to see if the drive dogs are stripped or motor is burnt out
Old 08-04-2007, 02:32 PM   #115
eb_5litre
It'll Buff Out.
Well I did what you suggested and will work great for the short-term. Will have to source a motor now.
Old 22-04-2007, 05:05 PM   #116
crankyTX5
I have a 93 TX5, On that car I have had a similar problem with most of the symptoms you are mentioning, especially the revs and loosing power and stalling when you are idling. Generally the power and reliability was all over the place. A new Air Flow sensor has done the trick.
Too expensive for a new one so I got one from the wreckers for $100. It is like a new car.
crankyTX5 is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2007, 04:23 PM   #117
dirty hands
Over Thinker
good to know the information in the posts helps all readers with some solutions
Old 04-05-2007, 12:22 AM   #118
CarNewbie
Hi there,
Not sure if you have covered this but a previous post wasn't quite the same trouble I am having. My '87 Telstar starts fine when it is cold. recently when my daughter was driving it the damn thing just stalled. It is possible to start it when it is warm but it won't idle. Once you put it in Drive, or reverse it stalls. It won't takr 'load' at all. The only way to get it home was to keep the revs up and 'ride' the brake. The local Ford place had it for 2 days and couldn't find a thing wrong. Our mechanic couldn't find anything after 2 days as well. Any ideas?
CarNewbie is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2007, 06:56 AM   #119
dirty hands
Over Thinker
try spark plugs first ... then coil ... start the car at night in the dark and see if the leads sparkle if they do replace them
then vaccume lines to the pots on the carby need to be checked
you do that by geting a length of vaccume hose attaching that to the poys on the carby / sucking in the end of the vaccume pots hold the pressure with the tip of your tounge and if it doesnt hold the vaccume operated pots need replacing
the telstars had problems with vapor lock when hot (mostly on stop start running from shop to shop for example )
I had to carry water and a rag--- soak the rag in water put it around the carby then wait till the fuel was cool eneough to pump up and start the car
I did buy a longer length of fuel line and foam type insulation over the hose that helped sometimes
Old 07-05-2007, 10:03 AM   #120
CarNewbie
Thanks for that. I'll try each of those when time permits.
The car is easy to start at any time. Just won't take a load, or idle.
Someone suggested it may have to do with some part of the exhaust system.
