16-08-2008, 01:36 AM | #451 | |||
Sly like a G6
Everyone always forgets something
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
16-08-2008, 01:38 AM | #452 | |||
Fiat POWAAH!
And now have added it to the list.. : Good pick up Sly : |
17-08-2008, 03:45 AM | #453 | ||
Holy hell, that was major overload of information!! On the plus side, it's helped me settle on only buying an AU s2 or s3 that way I don't need to worry about converting an s1 to the later series then converting that to the b series. Great thread overall though. Cheers
His: 95 EF Fairmont, lowered with lovells, boge and superpro, entertainment by jvc and alpine. Hers: 2003 stock as a rock BA xt e-gas Yay though I ride through the valley of the shadow of death I shall fear no evil, for I am the meanest motherf****r in the valley. |
30-08-2008, 06:00 PM | #454 | |||
30-08-2008, 06:18 PM | #455 | |||
I miss my wheelbarrow
The only thing I am unsure of is whether the 3mm rear caliper offset difference is restricted to AU series 1 only, or if it continues through the whole AU range. Bearing in mind the T3 uses the same rear Brembo caliper as the B series FPV's, it would make sense that only the AUI is affected. Daniel |
01-09-2008, 11:46 AM | #456 | |||
Red is nice Mark.
Twin T3's TE 50 #72 Blueprint & TS 50 #105 Blueprint : |
04-01-2009, 07:17 PM | #457 | ||
got a question do front territory brake calipers bolt straight onto au2/3 falcon some people say they do some say they dont im looking for a 100% answers has anyone fitted them?
cheers clint |
04-01-2009, 07:20 PM | #458 | ||
No. They do not.
AU2 XR6 VCT...
Powered by Vortech : T1 TE50 #094 : |
04-01-2009, 07:32 PM | #459 | ||
I back up the above, they do not fit.
BF XR6T/XR8 calipers do fit with the appropriate larger discs though.
'09 SYII TTG | Mystic '06 BF XR6 | Mercury Silver
04-01-2009, 07:45 PM | #460 | ||
have either of you guys tried to fit them....ive read a few posts from guys with BAs that say they fit
http://www.fordforums.com.au/showpos...99&postcount=6 http://www.fordforums.com.au/showpos...59&postcount=2 so if they fit a ba they should fit a au3 id like to hear from someone that has actually fitted or tried to fit them... |
04-01-2009, 07:52 PM | #461 | ||
Fiat POWAAH!
I'd say this post confirms that they don't fit:
http://www.fordforums.com.au/showpos...23&postcount=4
Holden: If you cant beat them, buy them. |
04-01-2009, 07:54 PM | #462 | ||
yeah youd think those guys would no hey thanks for that.....
04-01-2009, 08:22 PM | #463 | ||
Abuser of Charvels
What those posts meant is they have the same as Terry brakes, but the calipers for Terry don't suit the Falcon and vice versa. They seemed the same until someone bought them and tried to bolt them up. The calipers are essentially the same thing, but due to different front ends, mount differently and you can't really change this.
FG has the Terry suspension at the front so they may be a direct fit, but if so, FG couldn't use BF XR6T/XR8 calipers. Get it?....lol...
04-01-2009, 08:42 PM | #464 | |||
www.TUFFCARPARTS.com
I've got a full set of Territory rotors & calipers front and rear sitting here, but haven't bothered trying to fit them yet, as I was gonna wait till my current pads are worn out.
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
04-01-2009, 08:46 PM | #465 | ||
Back to N/A land
I tried to fit Territory fronts on my car... No fit... XR Lita and Perana confirmed this as well
04-01-2009, 08:51 PM | #466 | ||
I have tried as well, and they did not fit. Checked on both an AU2 and my BF
The Front and Rear discs and Rear calipers do fit on AU2 Live Axle, though the rear calipers do need small spacers. Must get around to organising a set for my BF now
04-01-2009, 09:06 PM | #467 | |||
29-01-2009, 03:32 AM | #468 | ||
What size discs do the FG XR8 have. I thought it would be the sames as the BF XR8s in having the 322mm fronts and 328mm rears but when i measured the rear discs off a FG XR8 it only came upto 303mm. Is this right?
I do beleive that the FG Falcon front and rear brakes fit onto AU2/3 as well. Not sure if they are bigger then the BF brakes though.
Current: Built R32 GTR 520Hp ATW AU3 Fairmont I6 Whiteline swaybars, FPV Typhoon Rims, Superlows, Custom Intake Piping, Modified BA XR8 Airbox, Big Stereo Past: 2001 AU2 XR8 220 Manual 1/4 Mile: 13.8 @ 100MPH (161km/h) Ford Falcon AU2 V8 Auto 1/4 Mile: 13.0 @ 107MPH (172km/h) |
29-01-2009, 08:15 AM | #469 | ||
Abuser of Charvels
The fronts of an FG may no longer fit, as the suspension has changed so they may now be in the same class as Territory, no go on the fronts, different mounts.
As for the rears, 303 is the size of BA/BF standard rears. Were they solid discs? BF XR8 got ventilated 328mm discs, ca you check again?
29-01-2009, 06:45 PM | #470 | |||
Its definetly a solid disk and i measured it again and from 1 side of the disk to the other it measures up to 303mm. The brakes are off an FG XR8. Looks like i will have to sell these and get hold of an FTG rear brake kit as i dont think a 303mm disk will work well with brembo brakes at the front.
29-01-2009, 08:41 PM | #471 | ||
ive noticed the the fg calipers bolt on opposite to au at the back of rotor not the front.....hears some for-sale http://www.fordforums.com.au/showpos...84&postcount=1
29-01-2009, 10:46 PM | #472 | ||
If they are only 323mm that 1mm difference from FG to BF would be hardly worth mucking around to see if they do fit.
30-01-2009, 02:59 AM | #473 | |||
That is the guy i bought the rear brakes and the brembos off lol. They bolt up the same as the AU2-BF and if the FG brembos fit then i dont see why the PBRs wouldnt. I dont know why Ford would down grade the rear brakes to a solid disk 303mm for the latest model XR8 :
30-01-2009, 03:09 AM | #474 | ||
I think this answers my question about the rear FG XR8 brakes:
http://www.ford.com.au/servlet/Conte...=FOA&c=DFYPage They did downgrade the XR8 brakes to 303mm solid disk rears. Anyone know if you can run a 328mm disk with the calipers or will you need a different caliper bracket?
30-01-2009, 10:56 AM | #475 | ||
Back to N/A land
Calipers are completely different for the 328mm rotor.
The 287/303mm Calipers are the same part number with a different mounting bracket Also, have you actually test fitted those FG Brakes ? FG suspension setups are completely different (Good news for us AU guys if they actually do fit though!) |
30-03-2010, 01:36 PM | #476 | ||
for any one interested i priced some bf xr8 calipers front only from a wreckers yesterday , they want $350 as they come off the car, i also priced for a brake place to rekit the wreckers calipers ....they want $85 each caliper, i would`nt put 2nd hand brake parts on without recoing them, the wreckers price is a little rich in my book, i also rang ford spare parts for the same they want $350 each brand spanking new.
30-03-2010, 02:16 PM | #477 | ||
Critical Thinker
Nice thread mine mik. Makes you wonder what the point is buying off a wrecker with those prices.
30-03-2010, 02:38 PM | #478 | ||
yep for sure, at that price from the wrecker it`s not worth the mucking around imo, did you end up doing the brake
upgrade shav? |
30-03-2010, 03:37 PM | #479 | |||
Critical Thinker
30-03-2010, 06:48 PM | #480 | ||
does any one some old au 2 xr6 pads and some standard ba pads? a couple of pics just for comparison of the surface area, that would be tops , thanks.
