Old 12-08-2020, 08:19 AM   #1
niallnz
Fairmont Ghia
Default 2007 Focus noise after engine off
So the wife's 2007 Focus made this odd noise after turning off the engine. It went on for about 2minutes and stopped with solid clonk like a solenoid closing. 2litre petrol, no check engine lights, my thought was the idle control valve.
Now 2009 Fiesta Zetec (the daily)
2007 SY Territory Giha (the weekender)
Previously 1991 EA II Fairmont Ghia, which was fun while it lasted, and in the dim dark distant past a Mk3 Cortina XL facelift, with the 2l pinto
niallnz is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2020, 11:57 AM   #2
russellw
russellw's Avatar
Default Re: 2007 Focus noise after engine off
Can't playback the audio it just gives an error.
Old 12-08-2020, 08:54 PM   #3
niallnz
Fairmont Ghia
I'll try again, hopefully the link work this time. Any thoughts on the source and/or course?
https://www.youtube.com/watch?v=uhf2tiGDv6g
Old 13-08-2020, 09:15 AM   #4
Peter B - CV8
Not sure about the Focus - but quite a few cars are designed to do this. Pretty sure it's part of the fuel/emissions system ie fuel purge solenoid shutting off after it's done it's job.
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2020, 07:58 AM   #5
niallnz
Fairmont Ghia
Thanks for the thought. It sounds like something is being modulated. For a evap/purge I would have thought that a valve would be held open and it would be pretty quite.
Old 15-08-2020, 09:54 PM   #6
ernie1
Fairly common for the drive by wire throttle motor to cycle after shutdown. They will occasionally do a self test but some do it more often for whatever reason. Feel for a slight vibration on the throttle motor when you can hear the noise.
ernie1 is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2020, 02:07 PM   #7
leakey
leakey's Avatar
Mine's not so loud, nor does it run that long! But I have a similar sound, but sounds more cool, like a little jet engine spooling down.
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR
leakey is online now   Reply With Quote Multi-Quote with this Post
Old 30-10-2022, 05:14 PM   #8
LTLXfocusCBR
+1
Feel like a jet pilot pulling in. 07 LT with 2L petrol
LTLXfocusCBR is offline   Reply With Quote Multi-Quote with this Post
