Can a s2 AU XR cluster be modified to fit a S1 XR?
thanks. |
Yes - there are small differences in plugs but with a bit of wiring modification it can be done.
Cheers Russ
R.I.P. Maggie
Geres another one; is an S2 cluster the same as an S3?
AUII XR8 200Kw Ute FG XR6T 1976 289 Mustang (Gone) |
RIP...
Yes.
. Oval Everywhere... |
R.I.P. Maggie
Spanner Thrower
What plugs are different Russell? Or just a moved pin here and there? (S1 futura with a s2 Fairmont cluster. Did have to move 4-8 wires.)
1999 AU Futura Wagon (Nickname Betsie the Barge-***) Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG. Awaiting Wife Approval Mods: TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things! |
Next upgraded Mk1 Leopard
Look in mu 1st AU build I swapped wires from a standard loom to make a high series work.
UK
Spanner Thrower
I knew about the swapped wires (done the same plus got the doors to light up individually)
Pretty sure the physical plug was the same though.
What i would like to do is swap my
s1 tickford fascia for a s2 blue cluster and have all features function,,thanks for your replies. Last edited by TK-421; 24-02-2016 at 09:48 AM. |
Spanner Thrower
Ok so changing from a low series (it'll have speed and rpm, fuel and water temp) to a high series (adds oil pressure and battery voltage) right? 4wires need to be moved around and you have to replace the oil pressure switch with an oil pressure sender. If they both have the same gauges then it'll be a straight swap.
Any difference between XR ute and sedan? My cluster in the ute needs replacing, found a great same user but from sedan. Would hate to throw a code or plugs not fit.
Sent from my SM-N986B using Tapatalk
2005 BA Mk 2 Fairmont, riding dirty on Pedders Sports Rider and limo tint, rolling on 18's, hand of god pushing passengers into their seats with a tuned 232rwhp and 470Nm Previous Rides: KH Laser TX3 EF Futura (RIP) EL XR6 AU2 XR6 BA XR8 BF XR8 BF Wagon (XR6 Lookalike) 2014 Ford Ranger 2000 AU XR8 with all the options boxes ticked (RIP) G.M.H. - Get a Mechanic...Hurry!! |
#12 | ||
![]() Join Date: Jun 2007
No difference mate
