HOWDY, I have a 2016 MD Duratorq.
Before I start removing random splash panels, where exactly is the oil filter? |
Its on the LHS of the engine which being east-west its at the front of the car just behind the radiator. Here is a view from underneath..
MD Mondeo 2.0 Durotorque Oil filter .JPG |
![]() Join Date: Oct 2006
Also https://www.youtube.com/watch?v=aq4cI-RjaWU Ford Mondeo mk5 2 litre tdci oil & filter change .
regards Blue |
Perfect - Thanks guys
Note also Ford say these sump plugs are single use and should be replaced each oil change. Nonetheless, if removed and installed carefully, they usually can be reused several times in but it also pays to always have a new one on hand in case you find when it is removed it is worn, damaged or distorted or been reused several times already so it may leak or falls or gets damaged on removal. Ryco makes one per https://www.ebay.com.au/itm/16397344...Cclp%3A2544595 that is half the price of the factory one per https://www.ebay.com.au/itm/22345432...oAAOSwNZRfMj3U
regards Blue |
