Old 22-06-2021, 05:54 PM   #1
Edxr6
Default Oil cooler leak
Guys,
I had notice today whilst the car was up on the hoist, there is oil weeping from the oil cooler at the oil filter end. Is there o rings or gaskets where the hoses connect into the plate or the plate attached to the block, just curious where the oil may be coming from.
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2021, 02:24 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Question Re: 220 Oil Cooler
Originally Posted by Uncle_Ken View Post
the new seal
Do you mean this?
