09-10-2006, 11:19 AM | #1 | ||
Would an Au xr8 Engine cover fit onto a EL XR8 engine? What kidna of cutting and manipulation be needed to make it happen, does anyone Know of anyone that has done this before ?
09-10-2006, 11:35 AM | #2 | ||
Tuned @ Pitlane Frankston
It will fit, but you need to find a new mounting point up the top of the engine, as there is a plate that says 5.0L on the top of the intake where the four allen key bolt usually go..
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
09-10-2006, 12:22 PM | #3 | ||
Will it fit straight on? Is there any cutting involved ?
09-10-2006, 01:13 PM | #4 | ||
i THINK the bottom 2 holes line up with the cover. There could also be issues involved with the top part of the cover hitting the EGR stuff, as AU's didn't have it.
09-10-2006, 02:21 PM | #5 | |||
Could be alot of messing around, but the result would make it worthwhile. The E-series 'BBQ Plate' engine covers are pretty craptastic.
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
09-10-2006, 04:29 PM | #6 | ||
I've got one here, doubt it'll clear the EGR. You'll need different brackets up the front.
09-10-2006, 06:52 PM | #7 | ||
Oops, I slipped....
The AU one mounts to the manifold differently, and the AU one won't clear the E-Series dizzy and coil, as well as all the other reasons above.
Engine covers are for poofs btw :P
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" Last edited by Aaron_EF8; 09-10-2006 at 07:32 PM. |
09-10-2006, 07:40 PM | #8 | ||
Ah coil, that's why mine doesn't want to fit properly. Meh.
09-10-2006, 07:40 PM | #9 | |||
Riding The Lightning
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA |
09-10-2006, 11:00 PM | #10 | |||
there are heaps of painted/chromed/chopped covers around. some look good (if done well, and not painted weird colours)
Heritage Green EL Ghia Black AUII XR8 Ute |
09-10-2006, 11:04 PM | #11 | |||
13-10-2006, 12:33 AM | #12 | |||
Bump bump bump.
Well, it fouls on the thermo fans, but a bit of hacky hacky will fix that. And I didn't have a snorkle on. |
30-10-2020, 11:20 AM | #13 | ||
My EB XR8 is missing the engine cover I'm thinking of getting an engine plate off a AU 5litre and just replacing the engine plate, my question is is it a straight swap will it all line up , ive seen on ebay plain plates which look ok but I prefer the AU because of the 5 litre printed on the plate
