25-12-2009, 10:39 PM | #1 | ||
help with engine how do i get torque settings and specs related to this engine online for free? ax Telstar V6 5 speed? repair guides etc
26-12-2009, 03:40 PM | #2 | ||
BUMP any experts in the building?
26-12-2009, 03:52 PM | #3 | ||
Clevo Mafia Inc.
I don't recall the Telstar ever having 6 cylinders in Australia.
http://en.wikipedia.org/wiki/Ford_Telstar |
26-12-2009, 04:01 PM | #4 | ||
Now Fordless
Telstar definitely had a V6. 2.5l same as the Probe. That wiki says only in NZ which is wrong.
Probably going to be difficult to find a complete database for a car like this as they arent that common. Best to just spend some coin on a manual from Repco or similar place. |
26-12-2009, 04:41 PM | #5 | ||
Fordaholic
It is the KL motor that Mazda put in the 626 should be an all alloy motor if it is I can supply big End, Mains, & Head bolt torque.
Cyl Head: 1st step 23-26nm 2nd step tighten to 90 degrees 3step tighten a further 90 degrees Big ends: 1st step tighten to 22-27nm 2nd step tighten to 90 degrees Mains: Eight inner bolts, 23-26nm Eight outer bolts, 18-21 nm. Number 4 inner bolts (4 stamped on bolt head) tighten to 80 degrees. The remainder of the inner bolts ( 1 stamped on the head)Tighten to 70 degrees. Eight outer bolts, tighten to 60 degrees Please use this information carefully as it is supplied to you through datatek cheers. |
26-12-2009, 05:14 PM | #6 | ||
27-12-2009, 02:56 AM | #7 | ||
Legendary stuff. Cheers.
