Old 06-03-2008, 12:06 AM   #1
Stav
Smile
Stav's Avatar
Default How to use slicks /front runners?
Guys. I have some mt slicks in my shed.I dont know how to use em. Will they give me better 1/4 mile et? How about the frontrunners? What tyre pressure do these things work at?
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 06-03-2008, 12:50 AM   #2
tel408
Your converter do this!
tel408's Avatar
They should give you better performance. Thats what they were designed for. Short sharp burnout is all that is needed. I run 33x15x15 and run about 7-8psi in them. Try starting at say 10psi and then go down 1psi per run and see were it likes it. These are cold figures. if you put in 10psi cold, afther a run they will go up around 1psi to 11psi. It is absolutley critical to check tyre pressure before each run to make sure that they are always the same psi as slicks have pouris side walls and constantly loose air. If you pump the slicks up and get say a squigy bottle of water, spray the side walls, and you may see air bubles.
Visit my Telstar drag car here
www.xr8ute.com/friends_telstar.php
A1 Performance Torque Converters
0403534803
tel408 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2008, 05:45 AM   #3
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
You may also feel the rear of the car drifting around a bit compared to the stiff walled street radials.
You are supposed to use the front runners with rear slicks as a rule.....due to the above.
You running a manual or slush box? Just so you don't embarrass yourself first time out, if you are stick shifting it.....they won't spin off the line and they can bog your motor right down if you don't launch with enough rpm. Nothing huge, but don't baby it too much or you could stall it ;) Auto = no probs!
They really make their money on a car that keeps spinning off the line and thru the gear changes. What's your current 60ft time? Does it spin? Do you have to granny it off the line?
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2008, 08:28 AM   #4
Stav
Smile
Stav's Avatar
It is a 4.0 na six. the car in its last outing pulled 2.068 and 2.078 60 footers. There was no wheel spin.I was using mt et streets. Hmm..I wonder if they will get me down the track quicker if I stall this up to the extreme max?
I never had traction before last outing. i had lsd conversions in the past and the car always single spun until last outing when I had the diff redone. It seemed the tyres never got hot but they didint spin either. I put this down to the diff. The slicks then may not make a difference to the et streets...? Correct?
Old 06-03-2008, 03:56 PM   #5
schnoods
schnoods's Avatar
Unless you have a big stall and leaving the line at 5000 rpm, i wouldnt bother with slicks, especially when your 60ft time is very good considering the power you have there. The MT streets are a very good tyre too.
A philosopher is a person who finds a problem for every solution . :Reverend:
95 EF XR8, Advance headers, Vortech V2 t trim blower, Ported Cobra Manifold, Capa Switch Chip Eliminator. 307 rwhp 395 ft/lb 13.2 @ 105mph
Now NA- AFR 165 heads, 1.6RR, Ported Cobra 269rwhp 14.2 ... needs stall and 4.11's
1977 CL Chrysler Panel Van, 360, 727 torqueflite auto soon to be restored.
schnoods is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2008, 06:19 PM   #6
Quadcams
Quadcams's Avatar
Location: Working, chasing after my daughter and working
Your MT streets will be fine Stav with the setup you have, dont under estimate Mt streets, very good tyre.
Quadcams is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2008, 07:50 PM   #7
ebxr8240
Performance moderator
ebxr8240's Avatar
MT streets tmk are radial so you can run your road tyres on the front..
Daily driver GTE FG..
Old 06-03-2008, 10:17 PM   #8
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
drag slicks and front runners mounted on light weight wheels may knock 2 tenths of your time, not from traction, but from lighter weight, less rotational mass to accelerate
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
