Hey Guys, Does anyone have any tips on how to access inertia reels for the rear seat belts on AU2 sedan?
Any help appreciated.
BlackXR8 |
Flairs - Truckers Delight
from memory you just pull the big fascia panel off and it's under there?
Yeh mate above the parcel shelf on the left and right is big white plastic sheets clipped in take them off carefully and there in there the middle seatbelt reel is under the parcel shelf itself just take out the clips and pull it backward towards the dash easy as
Also you'll need a six star Allen key or drill bit to undo the bolts
It's the outside pair I'm having trouble with. Are they in behind the panel adjacent to the rear window?
BlackXR8 |
#6 | |||
gone fishing
hope this helps you. I will be replacing mine soon and will post some pics if you want. cheers
Cheers Whiskers |
Thanks Whiskers, I'll give it a go.
Let you know how I went.
BlackXR8 |
Back in black
Arrrh! I got 2nd hand rear seatbelts to replace mine in the XR8 which are shot(Spring coils gone). On removal these new ones were fine. Now the two side ones are stuck locked. I can see the coiled springs is fine but they are locked tight and wont let any belt out. How do I reset them to let the belt out?
Black Mac TE50 S3 NO: 106 Little Mac AU S2 XR8 Bite the snake before it bites you! ______________ _.__ /________...\ _.._(___\\___//___) .._..(O...\____/...O) |
#9 | |||
How did you go mate. I got the same problem. |
Former BTIKD
![]() Join Date: Mar 2005
You do realise that Whiskers hasn't been online since 2014?
