Old 25-11-2013, 08:30 PM   #1
tkfd
tkfd's Avatar
Default AU XR8 and T-series brake MC differences
Hi Matt,
I have heard that the Master Cylinder in the AU T3-series is bigger than the standard XR8 - is this true?
tkfd is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2013, 09:45 PM   #2
XR27
Tickford XR8
XR27's Avatar
Default Re: AU XR8 and T-series brake MC differences
I have been told that the M/C is different on all AU's with premium brakes???
XR27 is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2013, 12:53 PM   #3
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by tkfd View Post
Hi Matt,
The answer pretty much is a yes as the series 3 was the last of the AU's and went to the larger stepped bore master cylinder.
The PBR catalogue lists various size master cylinders for sedan,ute and wagons.
Sedans 6cyl and V8 along with wagons and utes from 09/98 to 04/00 pretty much all had 22.22mm/28.57mm stepped bores but some utes had the 23.81mm/31.75mm set ups.
AU sedans 6cyl and V8's and the wagon along with the ute from 04/00 to 09/02 have 25.40mm/31.75mm stepped bore m/cyls.
The BA then went to the 23.83mm/31.75mm stepped bore master cylinder.
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 26-11-2013, 02:42 PM   #4
tkfd
tkfd's Avatar
Thanks Matt, this is a question from another thread thats going on, search MY AU3 XR8, errr T3 TE50 race car - in the Au Workshop Builds
Old 26-11-2013, 03:34 PM   #5
FLOORED
Race Brakes Sydney
FLOORED's Avatar
I will also mention that i have seen some utes with sedan master cylinders on them. The larger bore master cylinders will give a firmer pedal if thats what your after but the smaller bore have moe pressure.
Just like a garden hose
Small nozzell - more pressure less volumne
No nozzell - Less pressure more volumne
MATTHEW PEARCE
Phone 02 9609 1101
Old 26-11-2013, 03:48 PM   #6
tkfd
tkfd's Avatar
cool, thanks Matt.
I have the 2.5 MC on my car, that I race. There is no further upgrade to a larger MC then?
Old 26-11-2013, 05:19 PM   #7
FLOORED
Race Brakes Sydney
FLOORED's Avatar
cool, thanks Matt.
Are you referring to the 2.5 as the crack point on the proportioning valve? We do not have those figures available to us and it doesn't tell me what bore size the master cylinder is.
MATTHEW PEARCE
Phone 02 9609 1101
Old 26-11-2013, 05:28 PM   #8
BLU-220
FG XR50 TURBO
BLU-220's Avatar
Matt, would it be worth me upgrading to an AU3 m/c in my AU2 when i finally install the ba gt premium brakes the car will never see a race track thou.
Sorry to hi jack your thread tkfd
Cheers dean
BLU-220 is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2013, 05:46 PM   #9
tkfd
tkfd's Avatar
Hi Matt, I spoke to brake guy over here, and the upgrade he is referring to is retro-fitting of the bigger B and F series GT MC, that does not come with prop valve nut. Have you heard of this being done?
Old 26-11-2013, 06:16 PM   #10
FLOORED
Race Brakes Sydney
FLOORED's Avatar
No not sure on where that is going though as the AU3 master would and should be adequate. May i ask what car you have and what are you trying to achieve (save me some time)
Cheers dean
Leave the AU2 master cylinder on the car after you fit the brake upgrade and just see how the pedal feels to you before you change anything.
MATTHEW PEARCE
Phone 02 9609 1101
Old 26-11-2013, 06:46 PM   #11
BLU-220
FG XR50 TURBO
BLU-220's Avatar
just went took a pic of the master cylinder, numbers stamped on the nut are
fg
c3.1
25C0
does this mean it's been fitted with MC from a fg
Old 26-11-2013, 08:41 PM   #12
BLU-220
FG XR50 TURBO
BLU-220's Avatar
done a google search going by the part # on the reservoir it's the factory one
